Results 1 to 3 of 3
Thread: Radio install
    Default Radio install
    Thinking of changing my stock head unit to the Blaupunkt cd46 Bahamas, I am getting it from crutchfiled and they say that I need a special adapter the pac-2 to connect my stereo. But on bmwe34.net it says just get the harness and dont connect the negative speaker wires and use the new radios power attenea wire to turn on the BMW amp. Which way is right? Thanks guys.
    Bay Area, CA
    Well, both ways are right. The better of the two would be to use the Pac. This will drop the high level output of the deck to low level input into your factory amp.
    If you wire the BMW harness to your factory amp, you will notice that your system will distort quickly and the volume will jump to a higher volume more quickly than previously with your old radio.
    A way to skip using the Pac would be to use your radio's low level outputs to the BMW harness. THis will provide a low level output to your factory amp. This will yield the best sound quality.
    Find a set of RCA cables and cut the ends off it.
    Then strip back the insulation on each rca end to show the internal wires. You will have a center wire and a outwire that "wraps around the center wire"
    Strip back the center wire and tape off the rest of the wires.
    Connect each of the 4 rca's (newly stripped) to each input on the harness (white, grey, green, purple) using only the positives. tape off negatives.
    Then connect power, ground, and remote turn on lead to harness, taping off ALL speaker outputs.
    Connect your power harness to the radio and your rca's to each channel respectively.
    white=front left grey=front right green=rear left purple=rear right
    This should do the trick and should sound great!
    Greg Mannino
    Albany, NY
    Hey thanks for the great post Greg. I am going to give that a shot on mine. I have distortion at medium/high volumes right now using the high level outputs.
  1. Radio lights - source? Not Radio Shack
    By scott 4991 in forum 5 Series BMW
    Last Post: 12-29-2006, 05:55 PM
  2. Radio- e34 '89 525 install in '87 325is. Compat?
    Last Post: 06-05-2006, 09:02 PM
  3. HID Install
    By 93-525i in forum 5 Series BMW
    Last Post: 09-13-2005, 10:29 AM
  4. Anybody got suggestions for an XM Radio install??
    By tracye34 in forum 5 Series BMW
    Last Post: 04-13-2005, 04:11 PM
  5. Replies: 19
    Last Post: 01-23-2005, 01:05 PM
