Results 1 to 10 of 10
Thread: 525 thermostat
    East Brunswick, New Jersey
    Default 525 thermostat
    I never paid attention to the 80 deg C thermostat when I installed in May along with the aluminum thermostat housing the the SS impeller water pump. It has been giving me coolant message recently. I forgot I did the thermostat and bought one 88 deg C. Today I took it out because it was leaking, actually the car was overheating. The water pump o-ring was intact. So was the irregularly shaped red rubber ring. But the thermostat o-ring was very deformed, also with some crust. I also found the thermostat doesn't have a bleed hole. Those on my SAAB's all have one. While I don't believe in tampering with original equipment, what is the Board's recommendation on the bleed hole?
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Nov 2005
    Melbourne, Australia
    Was it a genuine BMW item? IMO it is a good idea, sticky thermostats are well known problem. Makes sense to have a pressure relief instead of blowing your rad apart. I dont think the bypass flow (with a small hole of course) would be sufficient to interfere with the function of the cooling system. It may not be ideal in very cold climate though..
    Cincinnati, Ohio
    i've seen the bleed hole recomended and did it on my car. works great just keep it small and put it as high as possible on the thermostat.
    Nov 2004
    Winston-Salem, NC
    Drill the hole through the arrow or marking that signifies "this end up" on the t-stat. Make the hole small, I can't remember the exact size, but the bit I used was one of the three smallest one in the set (1/16 or 1/32?). After the hole is drilled clean up any shavings on the stat and insert with the hole at 12 o'clock.
    -ashley
    Paper Gaskets Suck!
    Default I've never needed one on any that i've done but a number of
    people here drill them.
    Quote Originally Posted by yaofeng
    Hockinson, Washington
    What is the purpose of a hole??
    Mar 2004
    So Cal
    Some people say it helps in the bleeding process, but you don't need to do this on an m50 engine. I think it mostly helps on m20 & m30 engines.
    Greg Mendoza
    Quote Originally Posted by Mendozart
    I just poured in my coolant, squeezed the upper rad hose a bit, and started the engine. Once it was heated up, i opened the bleed screw. Since no air came out, i closed it and it has been perfect ever since.
    Default water pump
    For a while I thought I had a cracked head on the 525. After reinstalling the thermostat and water pump and filled coolant it started dripping. So I removed the AC compressor, the AC bracket, the two s-belt, all pulleys and the flex damper to have a look. Turned out the coolant was leaking from the bottom of the water pump to its mating surface. This is the SS impeller WP I put in three months ago. The WP o-ring is still very elastic. I am puzzled. Hope I don't need anther pump again.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    I must have messed up somewhere. As soon as I pour coolant into the tank, the leak starts at the thermostat/water pump area. Let me get this straight first. The thermostat goes into the block first pointed side facing out. The o-ring goes in next and then the thermostat housing. Correct?
    Have to take everything apart again. My driveway is all wet.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
  1. Thermostat Q
    Last Post: 07-13-2010, 07:50 AM
  2. -=(Thermostat)=-
    Last Post: 07-30-2007, 07:43 PM
  3. 540 thermostat
    By yaofeng in forum 5 Series BMW
    Last Post: 04-28-2006, 08:59 PM
  4. Thermostat, what do u think?
    By rockyfeller in forum 5 Series BMW
    Last Post: 11-23-2005, 01:19 AM
  5. Thermostat
    By spitfire in forum 5 Series BMW
    Last Post: 12-19-2004, 12:09 AM
