Results 1 to 10 of 11
Thread: Power Seat Switch
    Greensboro, NC
    Default Power Seat Switch
    Today while cleaning my car, i noticed my electronic seat adjuster thing didn't work, which is really bad since the day b4 i moved it all the way back b/c i vaccumed it out. Any info on this problem. Maybe it shorted out or something b/c when i tried to move it, it seemed like the lights kinda went dim and then went back to normal. Need some info on it b4 i get to messing around.
    Honolulu
    Default Can you hear the
    motor spin, or is it dead?
    Greensboro, NC
    as far as i can remember, i didnt hear any noise. my side panel on the seat is kind of warn and is loose, so i can easily reach the switch. When i tried to take a closer look at the switch, it seemed kinda loose, so im suspecting it might be unplugged maybe?
    Hockinson, Washington
    Is it just the forward/back adjustment, or the whole switch? Check your fuses. Its possible that your switch may have fried itself.
    Greensboro, NC
    the whole switch is not working
    NC
    Default You've blown the fuse under the back seat.
    Quote Originally Posted by Calico_NC
    Remove the seat bottom, and the fuse in question will be near the center of the car, beyond the keyless entry module. It's a 30Amp fuse, green in color.
    Been there, done that. I can replace the fuse in about 20 seconds by feel with just the left side of the seat popped up (hate to remove the carseat just to replace a fuse!)
    Bill B.
    95 525i
    Honolulu
    Default might be the fuse
    or check the plug to the seat harness, maybe you knocked it loose
    Greensboro, NC
    i'll check the fuse first, then see about the plug. how would u know if u knocked the plug loose?, Where do u plug it back in at? etc....
    Honolulu
    Default Under the seat
    you can't miss it
    Greensboro, NC
    okay i got it working, yall was right, it was the fuse. THANKS EVERYONE!
  1. Seat switch repairs
    By M20Turbo in forum 5 Series BMW
    Last Post: 05-11-2010, 06:30 AM
  2. Seat Switch Help
    By Jehu in forum 5 Series BMW
    Last Post: 10-28-2007, 07:23 PM
  3. Power Sport Seat Height adjust switch F'ed?
    Last Post: 10-05-2007, 01:51 AM
  4. Help need power seat switch
    By kick7ca in forum 5 Series BMW
    Last Post: 09-04-2006, 04:02 PM
  5. Anyone have a bad seat or window switch f/s?
    By rbeaud in forum 5 Series BMW
    Last Post: 09-02-2004, 07:08 PM
