Thread: EML/ASC question?
    Melbourne, Australia
    Default EML/ASC question?
    My 535iA (Australian delivery - build date 12/89) while not actually fitted with EML/ASC has both EML and ASC indicator lamps fitted to the instrument cluster.
    I read that ASC was not available on E34 535's until around the middle of 1990, though it was available earlier on E32 735's.... just curious?
    Also was does ASC really stand for? I see it mostly referred to as 'Automatic Stability Control', however I've also seen it referred to as 'Anti Slip Control' and to me this is a far more correct description.
    Then there is 'ASC' and 'ASC+T'... the later being referred to as 'Automatic Stability Control' plus 'Traction' control. This terminology would suggest that apart from controlling wheelspin the system also applies braking force to individual wheels to help stablilise the car under certain conditions... AKA 'Dynamic Stability Control'... though I thought this was only available on later vehicles like the E39 and after?
    On the E34's does ASC only reduce engine power to prevent wheelspin or also apply the brakes to individual driving wheels to prevent the wheelspin?
    ~30 Miles North of Chicago, Illinois
    I would also like to know the exact definition and workings of these slightly different features!
    [1994 530i/5-Speed]
    USA
    +T uses the brakes.
    Default It was available on the e34 in 89 just not very
    common, every dash that i've had out has had the indicator for eml on it just no bulb in it usually. Here's the info that i've posted many times in the past on asc and the various generations and what they control. The last column tells you what is controlled
    Quote Originally Posted by pundit
    Cheers! Thanks Bill!
    Sorry for the off topic but E28 also have the EML light. Were EML available at E28
    BMW FOR EVER
  1. Replies: 1
    Last Post: 11-06-2009, 07:35 PM
  2. Fuel filter question and bumper question
    By 1995 525i in forum 5 Series BMW
    Last Post: 08-26-2004, 08:22 AM
