My 535iA (Australian delivery - build date 12/89) while not actually fitted with EML/ASC has both EML and ASC indicator lamps fitted to the instrument cluster.
I read that ASC was not available on E34 535's until around the middle of 1990, though it was available earlier on E32 735's.... just curious?
Also was does ASC really stand for? I see it mostly referred to as
'Automatic Stability Control', however I've also seen it referred to as
'Anti Slip Control' and to me this is a far more correct description.
Then there is
'ASC' and 'ASC+T'... the later being referred to as
'Automatic Stability Control' plus 'Traction' control. This terminology would suggest that apart from controlling wheelspin the system also applies braking force to individual wheels to help stablilise the car under certain conditions... AKA
'Dynamic Stability Control'... though I thought this was only available on later vehicles like the E39 and after?
On the E34's does ASC only reduce engine power to prevent wheelspin or also apply the brakes to individual driving wheels to prevent the wheelspin?
