Results 1 to 5 of 5
Thread: What's that plastic bead on the bottom of the doors (under trim)?
    Toronto, Canada
    Default What's that plastic bead on the bottom of the doors (under trim)?
    Hi everyone,
    I spent the day yesterday grinding rust off the bottom of my doors. I'm putting POR-15 on it today.
    I was just wondering what that plasticized bead is and what it's for. I thought it was a weld, but it's definitely plastic. Some of it fell off when I pulled the trim pieces off. Do I need to replace it? Is it critical? Will the lower trim stay on ok without it?
    Mark
    Orlando, FL (Gainesville)
    If it was behind the trim pieces and plastic, I would imagine its to reduce vibrations? I dont know just a guess...
    Indianapolis, IN
    I believe its seam filler. Probably there to keep water from wicking up and causing rust between the inner and outer door skin. Worked real good
    Most of mine fell off too when I replaced my trim pieces. It did help make the trim fit on tighter but so far they have stayed on without it.
    Toronto, Canada
    That's good news I guess. So, should I just leave what's left? I think the POR-15 should take care of the rusty business, so I probably don't need to worry about wicking.
    M
    Indianapolis, IN
    Yep , the parts that were still stuck on solid I left attached.
  1. Exterior bottom door trim (Very Expensive!)
    By bimmerred535i in forum 5 Series BMW
    Last Post: 06-24-2009, 09:52 AM
  2. Where do I get trim for lower edge of doors?
    Last Post: 05-14-2007, 06:42 PM
  3. Rust on bottom of driver's door trim - 95 525i
    Last Post: 02-09-2005, 09:30 AM
  4. Leather trim on rear doors -
    By andyman32 in forum 5 Series BMW
    Last Post: 10-13-2004, 02:24 PM
  5. Bottom Door Trim 1995 Model
    By Don in forum 5 Series BMW
    Last Post: 04-19-2004, 05:39 PM
