Results 1 to 9 of 9
Thread: e34 540/6 engine ticking
    Default e34 540/6 engine ticking
    My beautiful e34 540/6 has developed a prominent ticking noise at idle. It decreases after the car runs for a bit and it is practically not there after an oil change. However, after a 300 mile drive yesterday (quick road trip) the ticking was very bad. It seems to be concentrated on the right side of the block and is more noticeable after a long run on the highway. I know it is related to the condition of the oil, but I just changed it two months ago and have only driven 2500 miles. What can I do to reduce this problem? Is there any additives or something. I know my car is leaking and burning a bit of oil so I keep a close eye on the level. WHAT VISCOSITY AND BRAND OF OIL DO OTHER 540 OWNERS RECOMEND??? THANKS IN ADVANCE.
    Jul 2004
    Kernersville, NC
    Have you checked the oil pump bolts? The M60 has issue with these going loose and falling into the pan. Search this forum for many articles on this and how to repair it.
    As to oil/viscosity, I use Mobil 1 0-W40.
    '95 540iA ~212k
    ditto, the pump may be missing all the bolts. pull the pan ASAP!
    Quote Originally Posted by stargazer_61
    Apr 2005
    So Cal USA
    The only oil I have tried and succeed in calming valve noise is Lubro Moly M0S2 Anti friction. They also go by the name Liqui Moly. I used it on my M50 525. Try it. you may need to mail order them because local auto parts store will not have them. it is not easy to find.. If you think it is oil related try that.. Also you may want to check on the oil pump bolt.. There is history of oil pump bolt backing out.
    95 M-sport SOLD now NSX
    USA
    i had massive slack in my chain.... and a missing bolt, and that was making my engine rattle.
    and yes, lubromoly moly treatment is the ****!
    they sell just the moly part that you can add to any oil as an extreme friction reducer.
    for the M60, run 0W40 full synthetic with one bottle of Valvoline Synpower oil treatment and one bottle of LM-MoS2
    if you live in death valley or somewhere that when you cold start the engine temp meter is always above blue, then go to 50wt
    Sep 2005
    Check your oil pump bolts.
    I use Lubromoly on my 540 too. Buy it from bavauto.com
    I think its 5w50
    Hockinson, Washington
    Will lubromoly work with Dinosaur oil?
    thanks for the advice. I should check those oil pump bolts. It should not be expensive to inspect right?
    May 2006
    NH
    Quote Originally Posted by 540ii
    You'll need a new lower oil pan gasket . i got charged $50.00 for it plus about an hours labour.
    1995 540i Manual build 1/95
  1. Loud Ticking noise ... Relative to engine speed?
    Last Post: 03-05-2009, 04:34 PM
  2. Ticking noise from top of engine
    By Mas (UK) in forum 5 Series BMW
    Last Post: 10-04-2006, 02:06 PM
  3. Ticking sound
    By danb7 in forum 5 Series BMW
    Last Post: 06-12-2006, 07:24 PM
  4. 1998 740IL Ticking From The Engine
    By CityMan in forum 7 Series BMW
    Last Post: 05-11-2005, 05:53 PM
  5. slight ticking from the engine
    By kyleN20 in forum 5 Series BMW
    Last Post: 04-05-2005, 01:43 PM
