Results 1 to 2 of 2
Thread: Rear door trim is stretched
    New E34 owners Guest
    Default Rear door trim is stretched
    We just purchased a 92 525, the back door trim is very strange, it looks like the vinyl has shrunk and is popping the trim inset out. When I was shopping I saw a 92 535 with the same problem. Anyone have a suggestion?
    Ontario E34
    Jon M. Guest
    Quote Originally Posted by New E34 owners
    Ontario E34
    You can either cut it in an inconspicuous spot and re-fit it into the door frame, or you can replace the trim entirely. Prices are somewhere around 65-75 per door, with the rears being slightly more. Call BMA, probably the best prices out there. I just did all four doors with new seals - it quieted the interior down noticeably, mine is also a '92 and those seals were getting a bit long in the tooth and brittle - causing interior squeaks etc.
  1. Door trim - gone.
    By Rustam in forum 5 Series BMW
    Last Post: 05-29-2006, 10:21 AM
  2. Door Trim
    Last Post: 02-08-2006, 04:45 AM
  3. Door panel trim help
    By ccrawford in forum 5 Series BMW
    Last Post: 07-10-2004, 11:25 AM
