Results 1 to 10 of 12
Thread: stock head unit removal question
    Richardson, TX
    Default stock head unit removal question
    I've been searching on here but haven't found a clear answer on this...
    I'm replacing the stock head unit on my 95 540i with a JVC KD-AR870 and I'm trying to remove the harness from the back of the stock unit. I see the picture on the head unit itself to get a screwdriver under the plastic at the top to pry up the sliding part of the harness. My question is this: Do I keep attempting to slide that plastic part UP to pop off the harness, or is it that now that that part is loose, I attempt to pull the harness AWAY from the back of the head unit? At this time, after using the screwdriver, that plastic sliding part is loose and moves up and down a couple of centimeters.
    Garret
    If you ever discover that what you're seeing is a play within a play, just slow down, take a deep breath, and hold on for the ride of your life.
    -Deep Thoughts by Jack Handey
    ~30 Miles North of Chicago, Illinois
    The way I remember it is that I slid the plastic part up, while at the same time, pulling the harness away from radio. I did this on a friend's 95 325i. Play with it, and just don't force anything.
    Richardson, TX
    Quote Originally Posted by Fetch
    At this point, I don't think that not forcing anything is really an option. But I know what you mean.
    Houston, Tx
    I slid, pulled, cursed, yelled, wiggled, fought, pryed and cried from multiple mosquito bites all to the symphony of that stupid radio alarm buzzer for over an hour. Eventually I *broke* that jackassed slider clip thing and wouldn't ya know it... the plug came right out within 30 seconds of working a flat-bladed screw driver between the molex and the radio body. After taking it off I plugged it back in to make sure I didn't mangle anything and all was well. Being in my car for 11 years it practically fused itself to the connector with heat, age an a little dust. If you snap that clip, don't sweat it, you won't need it for the adapter harness for your new radio anyway.
    Coventry, Midlands, England
    Prize it up (gently, with increasing force) with a flatblade screwdriver... Is what I was told by my local BMW specialist...
    Anyway, it worked for me, and my standard head unit was out in new time, and the new Kenwood in even quicker!
    1995 E34 520i SE Touring, in Calypso Red, Manual Box.
    Richardson, TX
    Quote Originally Posted by RiggsyB
    Prize what part up, though? I have the slider clip part as far along its "rails" as it will go. So do you mean to pry the harness away from the head unit?
    Albany, NY
    Quote Originally Posted by garretb
    Pry what part up, though? I have the slider clip part as far along its "rails" as it will go. So do you mean to pry the harness away from the head unit?
    Pry up on the top just like the diagram shows. The first 1/4 inch will be easy and then it will take some more effort. Just keep prying it up and it'll pop off.
    Richardson, TX
    Quote Originally Posted by SnakeyesTx
    Yeah, I started to wonder if it had just fused on there somehow, because no matter what I've tried, that thing hasn't budged. My only issue with breaking the clip is that if I ever sell the car, I would like to put the stock head unit back in so I don't want anything broken. But if it's a choice between keeping the clip and breaking it to install the new head unit, the clip is gonna go.
    Houston, Tx
    The slider is connected to the harness end. When you decide to revert back to original for any reason, you can still use the harness without that slider. That annoying clip is like a "There's no way this will come out" kind of paranoia device. There's no vibration strong enough to wiggle that harness back out of the radio especially since the bullet shaped connectors squeeze the pins on the opposite end. I didn't break mine on purpose at first, it just ended up that way so I broke the rest of it to "clean" up the harness.
    Richardson, TX
    One more question... is the plastic slider piece connected to the head unit or the harness?
    garret
  1. Replies: 4
    Last Post: 05-28-2009, 03:12 PM
  2. retrofitting stock cassette/radio head unit
    By Bruce Kennett in forum 5 Series BMW
    Last Post: 05-12-2006, 10:08 AM
  3. need a stock head unit for a 1991 525
    By marnold in forum 5 Series BMW
    Last Post: 08-28-2005, 09:28 AM
  4. Head unit removal
    By nuwde in forum 5 Series BMW
    Last Post: 08-24-2005, 07:06 AM
  5. Replies: 0
    Last Post: 06-25-2004, 04:45 PM
