Results 1 to 10 of 13
Thread: Stuck on heater core replacement
    Long Island, NY
    Default Stuck on heater core replacement
    I managed to get to the heater core quickly, but am having problems removing it. The new one came with pipes attached, and I'm hoping the pipes aren't the problem, and that by removing the core seperately from the pipes, I'll save alot of time and effort.
    However, after getting the front pipe dislodged, I'm having problems removing specifically the pipe that's closest to the front of the car(firewall). It won't budge, and it seems there isn't much wiggle room in the compartment that the heater core actually sits in.
    Any tips/tricks or advice on how I should procede?
    '94 540I 6spd/205000 miles
    Long Island, NY
    RANT RANT RANT!!!!
    Got old core out, and put the new one in...BUT....
    I used the old pipes, and they seat properly, but the bracket that holds the two pipes that attach at the left side of the core isn't fitting the new heater core properly.
    It seems that a plastic tab just below where the pipes mount is thicker on the new heater core, and the old bracket from the old pipes has a protrusion such that it hits the tab before seating fully so that the pipes can be tightened.
    What is the purpose in changing the tab and bracket on the pipes when they are otherwise the same?
    To that end, I presume I have three options. 1) sell the car. 2) try to alter the old bracket to fit the new heater core by shaving/grinding it. I have a dremel, but doing this with the pipes installed might be a pain, not to mention that the heater core is installed which makes that task even more risky and difficult. 3) install the new pipes that came with the new heater core, and everything should be happy-- I think.
    If I opt to install the new pipes, I haven't seen much in the way of write-ups on this. How difficult will it be, given that I have most of the interior already apart to follow through with the installing the new pipes? Do I need new gaskets or anything where the pipes enter the engine bay and connect to rubber coolant hoses?
    Thanks....so much for a trival 5 hour job.
    May 2006
    Columbus, OH 43212
    Default Install the new pipes...
    They should just pull right through the firewall to the inside with little work...heck you probibly already worked them loose anyway moving them around so much. I'm assuming that your new pipes have the firewall gasket thingie already on them like mine did, and you can just leave the old pipes connected, pull it out a little, then pull the pipes through the firewall...also saves a mess on the inside. Keep at it, and you'll figure it out, just try not to scratch anything since paint is very thin in this area.
    Long Island, NY
    Quote Originally Posted by saconnect
    Thanks... I'm leaning towards replacing the pipes as well. Do you know if I have to remove the dash to do this? Or is this pretty much a game of try to wiggle it through to the engine bay blind?
    Washington DC
    You clearly have no clue how to do this repair. JT540i and I spent several house just messing around with the damn pipes. They are extreamly hard to get through.
    I would do everything possible before messing around with new pipes.
    Benneton (United Colors of)
    i would bet that new pipes would make no difference in that latch closing down fully. the clasp is a "bitch" that requires that the pipes be 100% in, it really isn't like putting a heater hose over a nipple. anybody that has a 1/91 or newer e34 and has done a heater core can attest to that clamp being a PITA to get back on. if you have new pipes, by all means, go ahead and change them out while everything is apart, as you've hit an impass anyways.
    May 2006
    Columbus, OH 43212
    Quote Originally Posted by Eric Clark
    I do appologize sincerly if I've mislead you in any way, I was just tryin to assist...I have done four of these without a hitch, and three of them I've put on the pipes that came with the heater core, and I've never run into this problem. I'm getting ready to do my 94 soon, so I'll probibly run into it there...
    Pictures help a lot when you get stuck. There are a few tricks to changing the heater core on these cars that makes the job go much easier. Inside the engine bay right where the three pipes protrude the firewall there is a single clamp held by a bolt that keeps the piping in place when connecting the hoses inside the engine compartment. You want to remove this clamp for fishing new metal piping which I am not convinced even needs to be done.
    The trickiest connection is aluminum most driver side pipe to the core. Many spoil this connection which is a single bolt by pulling on the flange. One must rotate this flange not pull on it. When you get it apart you can bend the finger that goes behind the core to readjust for just the right amount of pre-load. The best trick for getting it back together is to use a long screwdriver and not your fingers to rotate this flange back into place.
    Anybody who needs help on here should own an inexpensive camera and post pictures. Many on here know every bolt on these cars and pictures make the difference.
    Good Luck,
    George
    P.S. the dash does not have to come out to change the piping however the piping likely does not need to be changed.
    Long Island, NY
    Here are some pictures of the stuck clamp. I have more pictures for documenting the whole process, but nothing better to show where I'm stuck yet. When I get the heater core back out I'll take a picture comparing the thickness of the two tabs.
    The pictures don't show the tab that extends out from the left of the heater core just below the pipes by the clamp that won't slide down into position. After thinking for hours it was the pipes themselves that was causing it to be stuck we eventually determined that the tab on the new core is about twice as thick inbetween the pipes as the old one.
    Long Island, NY
    Heater core out, old and new compared-- look at tab. There is a notch for the clamp to close on, and I'm unsure why I was unable to get it to do so in the car. In any event, old pipes are coming out, and new ones will be in. Hopefully this doesn't take too long.
  1. E36 heater core replacement
    By shogun in forum 3 Series BMW
    Last Post: 05-29-2012, 04:28 PM
  2. E32 heater core replacement - pics
    Last Post: 04-11-2012, 07:50 PM
  3. heater core replacement DIY instructions
    Last Post: 02-27-2010, 12:17 PM
  4. heater core replacement - pics
    Last Post: 12-18-2007, 01:30 PM
  5. Heater Core valve stuck open, any ideas?
    By BillionPa in forum 5 Series BMW
    Last Post: 06-29-2006, 08:07 PM
