Hey winfred, I dunno anyone else to ask.
You know I have the Holset H1E turbocharger ready to go, and so I ordered a "generic" oil feed and drain kit. The drain works out well as the Holset uses a T3 style drain flange so that's fine. However, the feed is a little confusing.
Here is the kit I have:
The line is -3AN which is recommended for the turbo, the drain is 5/8" and thats good too. However, the fittings there are 1/8" NPT, while the turbo inlet fitting are something larger. I know you're involved with trucks and all, so maybe you could find literature or something equivalent to Realoem.com but for trucks, because I need to know what thread pitch/type the inlet of the turbo is.
Here you see the turbo:
That brass fitting with the blue cap is removable. That fitting as some sort of female flare connection which is much larger than the 1/8" NPT fittings I have. When I remove that brass fitting, the threading is much closer, but still large. I am sort of pressed for time I need to find out exactly what adapter I need. So yeah, I am using a 1/8 NPT fitting so I guess I need to know what the turbo will accept and then figure out an adapter from there.
Thanks in advance winfred.
