Results 1 to 8 of 8
Thread: This ? is for winfred!!
    PA
    Default This ? is for winfred!!
    Hey winfred, I dunno anyone else to ask.
    You know I have the Holset H1E turbocharger ready to go, and so I ordered a "generic" oil feed and drain kit. The drain works out well as the Holset uses a T3 style drain flange so that's fine. However, the feed is a little confusing.
    Here is the kit I have:
    The line is -3AN which is recommended for the turbo, the drain is 5/8" and thats good too. However, the fittings there are 1/8" NPT, while the turbo inlet fitting are something larger. I know you're involved with trucks and all, so maybe you could find literature or something equivalent to Realoem.com but for trucks, because I need to know what thread pitch/type the inlet of the turbo is.
    Here you see the turbo:
    That brass fitting with the blue cap is removable. That fitting as some sort of female flare connection which is much larger than the 1/8" NPT fittings I have. When I remove that brass fitting, the threading is much closer, but still large. I am sort of pressed for time I need to find out exactly what adapter I need. So yeah, I am using a 1/8 NPT fitting so I guess I need to know what the turbo will accept and then figure out an adapter from there.
    Thanks in advance winfred.
    East Brunswick, New Jersey
    I am of course not Winfred but I'll stick my neck out anyway. Is the turbocharger water cooled? Anyway, typically the oil connection uses a banjo bolt and you need to practice your welding skill again I presume connecting the banjo bolt to some hard tubing. Check the link out. I am sure there are domestic suppliers too.
    http://www.robertsihn.de/index.php?id=36
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    PA
    Quote Originally Posted by yaofeng
    Actually Yaofeng, not to be a pain, but most OE turbo applications are not banjobolts. Additionally you wouldnt weld a banjo bolt to a hard line, as you can see I have stainless steel braided line.
    Of course my experience is limited to what I am exposed. All turbochargers on my SAAB's have banjo bolt connections for the oil lines and coolant lines. All banjo's are connected to hard tubings. And the lines and fittings are galvanized.
    I can tell you more about my SAAB 9k's but you wouldn't be interested.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    baton rouge, loserana
    for a drain id drill and tap the drain flange on the turbo and make a bolt on flange with a couple inch long 1/2"-3/4" nipple to clamp a flex line onto, that's the way most of the turbos i deal with have their drains, having a drain that's smaller then the feed line = blown turbo seals.
    you can see the nice flat area around the drain they just didn't drill and tap it
    Wellington,New Zealand
    completely OT
    interesting mix of STUFF on the bench:turbo, calculator,manifold, .....fork?
    Gone but not forgotten
    Jun 2005
    Quote Originally Posted by Paul in NZ
    completely OT
    Can you read the fine print on the drugs? I can't.
    it for some sort of BOOST problem
  1. OT: Hey winfred
    By Elekta in forum 5 Series BMW
    Last Post: 09-07-2004, 06:08 PM
  2. OT: Hey winfred
    Last Post: 09-07-2004, 11:54 AM
  3. Hey Winfred...
    By TC535i in forum 5 Series BMW
    Last Post: 07-21-2004, 10:39 AM
  4. Hey Winfred
    Last Post: 07-13-2004, 11:21 AM
