Hi everyone,
Just wanted to post the results of my repair activities in case anyone else runs into this type of scenario.
Sorry for the delay, but it took over 2 weeks for Pelican to provide all of the parts that I had ordered from them and then to compound the situation I ended up out of town almost 2 weeks.
I ended up doing the following to the car:
-- Checked/replaced all small vacuum hoses under the hood
-- Cleaned ICV but it was almost spotless inside before I started
-- Cleaned oil separator assembly and replaced O-ring & drain hose
-- Replaced valve cover breather hose
-- Replaced Cap/Rotor/Plugs with all Bosch parts (dist & cap had some corrosion but no moisture)
-- Replaced O-rings between throttle bodies and plenum
-- Replaced main relay and fuel pump relay
-- Cleaned all pluggable connections with and applied dielectric grease
-- Checked resistance & condition of plug wires and coil and they were OK
-- TPS checked per manual and measured 0 ohms at both idle and WOT
-- CPS (Crankshaft Position Sensor) checked out per manual
-- IAT sensor (in MAF box) checked out per manual
-- ECT sensor checked out per Bentley manual
-- Tightened all grounding lugs I could find under hood and rear seat
-- Fuel pressure checked out per manual
Bottom line, there were only 3 or 4 things that I am pretty sure were involved with the problem.
1. The upper ICV hose was totally loose where it connected to the center throttle body. This would be the prime candidate for a significant vacuum leak. Might have been from previous maintenence by FO.
2. The oil separator drain hose was rock hard and broken where it connects to the dipstick tube and was replaced.
3. Orifice in dipstick tube where oil separator hose connects was plugged solid. Cleaned out with appropriate sized drill bit.
4. Plug gap was 0.042 instead of nominal 0.024
So far, the car is running fine after all this work. I still plan to replace the O2 sensor as the records don't indicate that it has ever been changed.
Thanks again for all your input and areas to check out. MUCH easier to see what's going on with the engine when the plenum is removed.
Regards, Brent Dann
