Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Sealant for doing oil pan?
    PA
    Default Sealant for doing oil pan?
    Does anyone use sealant when doing oil pan? Bentley says to, dunno what kind I should get locally exactly or if its even recommended.
    Missouri
    I have great luck with the orangy colorored high heat silicone from uh.... PERMATEX ?? I think thats the brand.
    I'm out of it right now or I'd look. Seems that it was their blue with orange logo tube.
    I guess your turbo oil drain fittings are done ?Hope so, I know your getting Psyched !!
    .........Vinny
    AC Schnitzer | S-5 | Stainless exhaust | Bodykit | wing| 3pc. wheels | badges | springs | mirrors | steerwheel |
    Schwarz on Blk
    is that the gasket with metal sandwiched in the middle? if so no sealant used on mine and it's fine.
    East Brunswick, New Jersey
    Indeed you are cheap like me. All my SAAB's use blue permatex between the block and the sump pan. I use the orange Permatex between the timing cover and the block on my SAAB's too. I borrowed the experience and used it years ago on a 86 325es. It held to the day I sold it. I was going to do the same on my 525 for some reason people talked me out of it. I'd bet blue or orange Permatex work just as well as the over engineered BMW metal gasket with a bead of rubber.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    PA
    Quote Originally Posted by yaofeng
    How am I cheap though? I have a metal/rubber oil pan gasket but the bentley says to use a sealant and I just need to know which. Do I use just gasket or gasket and sealant?
    Sorry big spender. If you already have the metal gasket, why change? I am just saying BMW and SAAB has different philosophies of sealing polished metal joint. Both work. But SAAB's method is cheaper.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Do you mean sealant on top of the metal gasket? No. The metal gasket is supposed to be installed dry.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    PA
    Ok that was what I was wondering - I have like 3 or 4 metal/rubber gaskets and bentley said use silicone so I was a little confused. That's all - I am swapping oil pans out because I just got my other oil pan welded for turbo oil return
    you could put a dab of silicone in sharp corners and crap. the original gaskets might have been cork in the beginning?
    Albany, NY
    I'd prefer the gasket. That sealant stuff is a PITA to get off if you ever need to drop the pan again. Also you run the risk of sealant getting in to the oil supply. I'm not an expert though, anyone else feel this way?
  1. Headgasket sealant- M30 engine
    Last Post: 08-12-2007, 09:48 AM
  2. Valve cover gasket..Dry or with sealant?
    Last Post: 05-02-2007, 07:08 PM
  3. Radiator Sealant Stuff?
    By Jehu in forum 5 Series BMW
    Last Post: 11-19-2006, 06:10 PM
  4. Sealant
    Last Post: 12-06-2005, 12:37 PM
  5. Replies: 1
    Last Post: 11-08-2004, 03:37 PM
