Don't do it. It will cost you more in the end. a new t-stat is like $18 or less dollars depending on your housing, the gasket is between $5 - $9 bucks. Check out www.bmaautoparts.com if you order on the web type "DOTINFO" in the coupon code section for 10% off.Originally Posted by fclake
-ashley
