Results 1 to 4 of 4
Thread: bad antenna reception
    Jun 2006
    cali
    Default bad antenna reception
    just installed aftermarket stereo receiver and used the antena adapter to convert to motorola plug for aftermarket stereo and does not get clear reception from radio stations (95 5er) is their any way to check the integrated rear defroster antenna? has anyone encountered this problem?
    thanks in advance.
    Quote Originally Posted by speeddemon
    thanks in advance.
    The factory amplifier remote on must be connected to power when the radio is on as this same wire also powers the factory antenna.
    Usually the new radio has a remote on lead (blue) that shoudl connect to this. In my car the wire in the dash behind the radio that does this is white with a pink or red line... yours might be different as it is newer. Consult a wiring diagram for your model to know.
    If your factory amp is coming on this should be operational. I think the antenna can be accessed if you remove the rear coiurtesy lights nick
    Hockinson, Washington
    The antenna module is on the drivers side behind the rear pillar.
    Jun 2006
    cali
    Default antenna
    thanks for the replys , i have connected the white wire from the amp to the remote turn on and i still get bad reception the stereo works fine when the cd player is on . Do you know the wiring diagram to check the signal strenght in the antenna booster.
    thanks again
  1. Stock radio reception is failing?
    Last Post: 09-28-2008, 03:30 PM
  2. How do you improve radio reception
    Last Post: 05-21-2007, 07:09 PM
  3. improving radio reception
    By chamilun in forum 5 Series BMW
    Last Post: 10-17-2004, 12:56 AM
  4. Stock amp important for radio reception?
    By Kennan in forum 5 Series BMW
    Last Post: 05-02-2004, 07:15 PM
  5. Radio Reception
    By Svennn in forum 5 Series BMW
    Last Post: 02-13-2004, 02:56 PM
