Results 1 to 5 of 5
Thread: How to unlock a stuck double-locked rear door?
    May 2006
    Default How to unlock a stuck double-locked rear door?
    Hi everyone,
    My car has just developed a strange problem - my passenger side rear door is apparently double-locked (ie: the lock button will not move manually) and does not unlock with the rest of the system either.
    The result is that my passenger side rear door is now seemingly permanently closed since I can't open it to remove the doorskin and diagnose the lock situation.
    I have tried re-synchronizing the locks a few times but that doesn't work, or at least hasn't worked yet.
    So two questions please:
    1. Does anyone know what's going on with this?
    2. How to open the passenger-side rear door if it's double-locked and won't open with the rest of the system?
    Thanks for any help!
    Fusion
    Aug 2006
    Jersey, Channel Islands
    The central lock solenoid is seized. But in the end you can only replace it, any attempt to repare it will and in the same way as it is now.
    It is possible to remove the doorskin when the door is closed. Most probably you will brake feew plastic clips but nothing else.
    Dec 2005
    Los Angeles
    Quote Originally Posted by nuclearfusion
    Hi everyone,
    Fusion
    Not sure if this will work but give it a try.
    Lift the passenger side door handle insert the key and turn it clockwise. Turn the key while the door handle is lifted. That should open the door. If it doesn't work try it the other way around.
    A friend of mine showed me this trick when his battery died.
    Excess within control...
    1995 BMW 525i
    TC535i Guest
    I have a passenger door that's stayed in the "unlock" up position every since my girlfriend had to manually unlock them since the battery died. It "twiches" when you lock/unlock the car, but it still stays up (you can open the door when the car's "locked").
    Same problem? Something else?
    Thanks to Bill R. I have it copied
    http://i25.photobucket.com/albums/c7...nelremoval.jpg
  1. Replies: 11
    Last Post: 04-19-2020, 06:17 PM
  2. Replies: 1
    Last Post: 05-22-2009, 11:10 PM
  3. Replies: 7
    Last Post: 01-08-2009, 12:53 PM
  4. Driver's side door will not unlock! Button seems stuck
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 11-29-2004, 10:41 AM
