Results 1 to 10 of 12
Thread: Washer fluid low
    Knoxville,TN. USA,Earth,Milky Way
    Default Washer fluid low
    how do i bypass this sensor? it is is faulty and i have no desire to replace it, i just want the damm message to be gone.
    Honolulu
    Default check the sensor
    It's on the side of the reservoir.
    it can get rotated out of position, or the contacts for the plug get dirty. Both will give the error when to reservoir is full.
    Quote Originally Posted by Blitzkrieg Bob
    Thanks I'll check it, does the flat part face up or down?
    Honolulu
    Default Take a good look
    at the mounting point for the sensor on the reservoir, I think it is recessed with the same shape as the sensor, so the flat side lines up correctly.
    If that dosent work is there a way to bypass or trick it?
    Honolulu
    Default I am sure there is
    But I am the wrong guy for that sort of thing.....I'd rather fix it and have it work rather than start doing work arounds.
    The sensor is a simple float/magnet type of deal. Not much to break or fix.
    if it still gives you an error, make sure the float is moving, or try cleaning the terminal contacts.
    and if all else fails, remove the senosr and clean it.
    When I had this type of error, it was either the sensor was in the wrong position (error when turning or braking hard) and once the float was stuck after I removed and drained the reservoir on my Touring's rear washer to fix the gas flap lock.
    Derbyshire, UK
    Quote Originally Posted by fclake
    I forget whether it's normally open or normally closed, but it's simple to find out. Unplug the sensor connector. If the message is gone, you're done. If the message is still there, short the sensor leads. If the message is gone, you're done.
    1997 535i V8
    Albany, NY
    Come on, cough up the 30 bucks and replace it. The next poor sap that buys your car will be SOL when his washer fluid runs out without warning!
    http://www.autohausaz.com/search/pro...Level%20Sensor
    thanx for the link
    You can kill that thing easily. Just bridge the 2 cables in the plug for the sensor.
    Then it should be no alarm. If you still get the alarm, then one of the 2 wires is broken from the plug to the check control module. I just repaired that on my car last weekend. Very thin cables, they usually break close to the plug.
    I resoldered the wire.
  1. Why the hell am I getting the Washer Fluid Low message?!
    Last Post: 05-18-2008, 10:37 AM
  2. washer fluid leaking
    By gymkata in forum 5 Series BMW
    Last Post: 02-24-2007, 08:20 PM
  3. What I get for messing with the washer fluid
    By swenpro in forum 5 Series BMW
    Last Post: 12-19-2006, 11:59 AM
  4. Windshield washer fluid won't pump
    By donf in forum 5 Series BMW
    Last Post: 11-29-2006, 10:42 PM
  5. Washer fluid low problems - help.
    By Springfield1952 in forum 5 Series BMW
    Last Post: 03-23-2004, 11:40 AM
