Results 1 to 4 of 4
Thread: Help! Can't engage 1st and 2nd gear.
    Aug 2005
    Default Help! Can't engage 1st and 2nd gear.
    This usually happens after I've been doing some heavy speed (200kph) and causes quite a concern when I'm at the red light and simply can't engage into 1st or second with the clutch fully depressed.
    The symptoms are simple. After some rough driving, the friction point seems to become much much lower. I would normally feel the friction point anywhere close to the middle of the clutch travel. but it seems to become much lower, closer to the firewall after some spirited driving.
    Sometimes, I just have the lift the foot a little the find the car jerking forward.
    Now it simply won't even go into 1st or 2nd gear unless the car is not running. When I try to put it in gear at idle, it would slowly move forward (when 1st gear is not engaged but when I'm pushing slightly towards) and when I push harder, it grinds.
    Can anyone help?
    If anyone requires any additional information, please feel free to ask.
    Loving my Problem Child.
    M30 Manual / LSD / Prod. Date: 09-1989 / Basketweaves / Black Leather w/ rear headrests / Alpine Weiss III / 365k kms
    I would change the clutch fluid and bleed it and see if that helps.
    T·O·R·O·N·T·O
    Quote Originally Posted by White535Mtl
    Can anyone help?
    That's the key. I believe the first thing to look at is fluid and bleed.
    Agoura Hills, California
    you know what....i feel your pain. My M3 had the same symptoms, and only after I gased her a couple times...then i had problems engaging the gear. In my case though....I also had a slipping clutch plate. I installed a 4 puck, and drained a bleed the clutch twice....and it went away....
    The only problem i have now is i need a lot of throttle with the 4 puck since it grips like a mofo. AWESOME LAUNCHES without the traction control. But i think you need to just bleed like the two above have stated..
    1990 BMW 525i m20 SOHC 5-speed 140k miles, black on black, stoc
    http://www.born-today.com/Today/pix/tyson_m.jpg
    MAN WHAT?!?!...
    Everyone has to go on U-Tube and watch mike tyson interview
  1. 4th gear won't engage
    By Dan-ny-m398 in forum 5 Series BMW
    Last Post: 07-16-2009, 12:02 PM
  2. Key turns but starter does not engage
    By bissellh in forum 5 Series BMW
    Last Post: 05-15-2007, 09:15 PM
  3. Replies: 4
    Last Post: 04-15-2005, 02:03 PM
  4. Air con not working, compressor doesn't engage
    By Paul_540i in forum 5 Series BMW
    Last Post: 04-03-2005, 01:07 PM
  5. a/c compressor clutch doesn't engage
    By motuman in forum 5 Series BMW
    Last Post: 03-17-2005, 05:32 PM
