Results 1 to 10 of 15
Thread: Best sparkplug 540 with supercharger?
    Edmonton, Alberta
    Default Best sparkplug 540 with supercharger?
    Engine is an M60 with a Dinan supercharger. Thanks in advance!
    TC535i Guest
    Quote Originally Posted by Dr. Frank
    I'd go with a standard copper core, but go one temperature range colder. I had to get Iridium plugs for my 318 when I went s/c because they didn't sell a copper one any colder (in my fitment, I was at the coldest end of the range already with the stock plug).
    Nov 2004
    Get the coldest one that fits, if you are running more than 7 PSI boost. Exotic plugs may not be better. I find NGKs pretty good.
    TC535i Guest
    Quote Originally Posted by emw525E34
    They say one stage cooler for basic s/c, one for nitrous, and two for turbo. If you're running more than 7-8 psi on the s/c I'd go two stages... for a standard s/c application, one stage is cold enough, any colder and you're gonna start fouling them if you don't drive full throttle constantly.
    USA
    Denso IK27
    Sep 2005
    Hi Folks,
    I also have a Dinan stage 3 setup on my M60, M-Sport. The previous owner also put in the Dinan performance cams and a custom ram-air intake to go with the S/C setup. Sucker is very tractable below about 3000 RPM and screams to redline from 4000 RPM on, but the idle is very lumpy.
    I don't drive it like a mad man, but I definitely wind it out at least once every couple days. I'd really like to cure the lumpy idle (despite the hot cams in there), and have been thinking about putting in some Iridium plugs. I have had great success with them in my other cars (Toyota 2zz motor and a ZR-1), and the science behind the 0.4mm tip is very sound thermodynamics.
    I was thinking of going with the IK24 plugs (2 ranges colder), but reading this thread has me thinking about dropping down to IK22 for a smoother idle.
    Dr. Frank, what did you end up going with? How does it work for you? Do you also have a lumpy idle?
    Lastly, does anyone make a nice set of pre-cut spark plug wires for this car that are very high-temperature resistant?
    Thanks for any info, advice, or wisdom.
    -Burt
    USA
    no intercooler?
    Sep 2005
    Quote Originally Posted by BillionPa
    no intercooler?
    No where to put it unless you delete air conditioning or do a funky front bumper. However, a water injection kit might give you a little extra.
    PA
    They make an air to water aftercooler for the dinan setups I thought. It's just a simple vortech blower - I am sure you could do a small air to water unit.
    I run 2 steps colder in my turbo 5.
    Sep 2005
    Hi Guys,
    I haven't seen a Dinan intercooler available, and I've even spent some time on the phone with one of their technical guys.
    Jon, did you see this air to water unit from a 3rd party manufacturer or was it something custom? I'm not averse to either solution, since it's always a good idea to cool the intake charge.
    Right now it's completely original Dinan stage III, except for the ram air holes routed out up front.
    So without the intercooler, should I go with the IK24?
    Thanks again,
    -Burt
  1. Bosch sparkplug supersession list
    Last Post: 10-14-2007, 10:09 PM
  2. Electric supercharger
    By jordansportsfan76 in forum 5 Series BMW
    Last Post: 03-07-2007, 01:29 PM
  3. Turbo or Supercharger for E34 M-5?
    By 91m5 in forum 5 Series BMW
    Last Post: 09-11-2006, 12:46 AM
  4. supercharger
    By m3iceman in forum 5 Series BMW
    Last Post: 03-19-2005, 09:57 PM
