Results 1 to 9 of 9
Thread: 520 (M20) very poor economy
    Aug 2006
    Jersey, Channel Islands
    Default 520 (M20) very poor economy
    Hi everybody,
    Thats my first post on that forum.
    The problem that I have with my 520 is a little bit strange. I was reading foult codes several times without sucsses but car is very badly overfueling all the time. The niddle on econometer usually is out of scale. The economy is around 10 mpg during very slow normal driving. I have checked HT leeds, rotor arm, distributor cap, replaced spark plugs and it is still the same.
    Any sugestions?
    Cheers,
    Jan
    Derbyshire, UK
    I assume you've verified that it actually is running rich, and it's not just a bogus reading on the meter. Does it have an oxygen sensor? If so, check that. Also check the AFM and coolant temperature sensor for proper behaviour. It might be perpetually running in cold enrichment mode.
    1997 535i V8
    Aug 2006
    Quote Originally Posted by DaveVoorhis
    Yes the real fuel consumption is dramaticly too high.
    No, it haven't lambda sensor.
    Do you know what impendance shoud be on that sensor when cold and hot?
    Cheers,
    Jan
    Derbyshire, UK
    Quote Originally Posted by Yaninnya
    It's the sensor on the thermostat housing with the blue connector.
    According to the Bentley manual, at -10c it should be 7 to 11.6k ohms, at 20c it should be 2.1 to 2.9k, and at 80c it should be 0.27 to 0.40 k ohms. It's a continuous resistance sensor, so the actual value will depend on actual temperature.
    If it isn't the coolant temp sensor, I'd suspect the AFM. The flap can get sticky, or the resistance track inside can get dirty or worn.
    BTW, are you sure it's an '87 520i and an E34? E34 didn't start until the '88 model year.
    1997 535i V8
    T·O·R·O·N·T·O
    Okay, so what's the overall economy on a tank of gas, or is that what you're trying to say?
    Assuming you're talking about US Gal, then it's about 23.5L/100KM... which is usually an entire tank of spirited driving for me...
    Aug 2006
    Many thanks for that info, I will check it soon.
    You are absolutely right. My second BMW (318i) is '87, that's the reason of that mistake. My 520iA was first registred in August '88.
    Quote Originally Posted by Qube
    Okay, so what's the overall economy on a tank of gas, or is that what you're trying to say?Assuming you're talking about US Gal, then it's about 23.5L/100KM... which is usually an entire tank of spirited driving for me...
    I'm taking about Imperial Gallons, I'm living in Jersey on Channel Islands (near England ). But because I,m polish it is easyer for me to state it in L/100 km. It is around 24-27 L/100 km. A lot to much. Even with auto it shoud be around 12 L/100 km.
    T·O·R·O·N·T·O
    Hmmm... is 12 L/100KM optimistic? Of course I've got a 535 and can only pull down to 17/18 L/100KM at best. Of course, in the 1.8T Passat, I average 7.5L/100KM (yum!).
    Aug 2006
    I don't think so. Here on Jersey is 40 mph speed limit and the roads are so twisty and narrow that it is not so easy to drive with higher revs than 1600 - 2000 rpm (it is auto tranny).
    Quote Originally Posted by BillionPa
    does the engine idle unstable?
    Now (when it is not running for feew weeks) they are quite stable. But when problem began it was hard to keep it running on idle so unstable it was.
    can you smell gasoline from the exhaust during idle?
    Not too much and during driving there is not black smoke from exhaust even during harder acceleration.
    Cheers,
    Jan
    USA
  1. OT Fuel Economy 376.59 mpg
    Last Post: 11-05-2008, 09:23 AM
  2. Really poor cold running, less poor warm
    By Ross in forum 5 Series BMW
    Last Post: 05-22-2008, 09:59 PM
  3. why am i getting such bad fuel economy?
    By adashio in forum 5 Series BMW
    Last Post: 08-30-2007, 02:03 PM
  4. 525 tds fuel economy
    By superkev525 in forum 5 Series BMW
    Last Post: 03-04-2006, 07:44 AM
  5. Fuel Economy?
    By Whit in forum 7 Series BMW
    Last Post: 07-20-2005, 12:49 PM
