Thread: When doing M50 oil pan...
    PA
    Default When doing M50 oil pan...
    Is it best to lift the motor up or drop subframe? Do I just undo the front engine mounts and lift up or do I need to screw with the trans mounts to et the right angle? About how far does the motor need to come up?
    PA
    no body?
    easyer to jack it up and put some wood blocks under the motor mounts to make it sit higher
    Dec 2005
    Mt. Vernon Ohio
    Yeah it was a major pain in the ass on my M50TU even with it jacked up :\
    NovceGuru
    1993 525iA M50TU
    Black on Black...need pics
    208,888 miles
    PA
    Do i have to drop the oil pump?
    depends on how high you can get the motor, i do a **** load more m30s where you do need to drop the pump, i can't remember if you can get away without it on the m50, it's not a big deal if you do though
