If the threads are std Metric, you could get a bolt that fits at a hardware shop. I snapped my bleeder plastic bolt, but it was std M10 threads so i used a M10 bolt meanwhile.
I went to flush the radiator today and snapped the blue plastic drain screw on removal. It drilled out easily, but where do I find a new one Quick? Dealer would have to order it, and no one carries anything like it. Until I can find one I have no car. Any Suggestions? Thanks
Eurospec-12/1988-535iL-M30B35-5speed
that is a great idea espen......it should be metic since its probably a behr radiator which is german made...which in turn would mean its metric.....go to home depot or doit center. I always get my o rings there. Instead of paying 2-3 bucks.....30 cents!
1990 BMW 525i m20 SOHC 5-speed 140k miles, black on black, stoc
http://www.born-today.com/Today/pix/tyson_m.jpg
MAN WHAT?!?!...
Everyone has to go on U-Tube and watch mike tyson interview
i had the same problem with my bleed screw on top of the radiator , i found a bolt that fitted exactly, good to go , no problems
