"COOLANT" on message center
My 1990 535i was leaking coolant from the water pump gasket, so I had the water pump replaced. At the same time I had a new radiator put in as the old one was weeping a little from some of the seams. The system has been filled and pressure tested and there are no leaks, but the message center still flashes "COOLANT" when I start (and turn off) the car.
I'm sure that the sensor could be bad, but is it possible that there is air in the system? If so how would I bleed the air out? Finally, is there anything else I should be considering or looking for?
Thanks in advance for your help.
- Hal
1995 325i 5-speed, 113K - Now
1984 325e 5-Speed, 2001 325i 5-Speed, 1995 530i 5-Speed, 1989 535iA, 1997 540i 6-Speed, 1990 535i 5-Speed, 1996 328is 5-Speed - Past
