Results 1 to 5 of 5
Thread: 3rd gear problem
    Yorba Linda
    Default 3rd gear problem
    My car is a 90 535 5 spd with 133k miles. Lately, when shifting into 3rd from second and sometimes during a downshift, it grinds. Now, this does not occur at lower RPM's, but above 4K, it happens about 75% of the time.. Clutch seems Ok, doesn't happen in the other gears. I'm running Redline in the gear box, diff and clutch. Could it be a syncho? Trannny problem? Is it time for a clutch and flywheel change??
    Near San Francisco, CA, USA
    Default Seems like since it does not happen in 1st & 2nd,...
    that the clutch is OK. So, that leaves linkage problems and internal problems. Most E34s have worn out (to some extent) linkages at 133K. Requires removal of exhaust and DS to access, so its not that easy a job, so usually it doesn't get done unless there's a crisis. Sounds like you may be having one.
    Quote Originally Posted by caster
    A quick thing you can check is your engine and rear tranny mounts. I'd take a peek at them and see if there are problems. No need to remove exhaust or driveshaft to r&r.
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Mar 2004
    Cambridgeshire, UK
    Have you tried double de-clutching on the downshift? If this cures it, I think that points to synchromesh issues. (Long time ago though...)
    And if double de-clutching is double-speak, it's this: depress clutch, take car out of 3rd gear. As you move the lever across the gate, in neutral, fully raise, then depress the clutch. Now engage 2nd gear. With practice, this can be done very quickly...
    nova5 Guest
    Default synchro on 535i
    my 535i started doing the same in 4th gear. It would just pop out of gear under load. I could hold it in with my hard. But now it won't go in at all unless I double clutch.
    What's involved in a synchro rebuild?
  1. HELP! - Gear problem since oil change
    By anonymous1 in forum 5 Series BMW
    Last Post: 04-13-2008, 09:39 AM
  2. BMW E36 328i Coupe Sport Gear Change problem???
    By sixpotbeemer in forum 3 Series BMW
    Last Post: 03-21-2008, 07:52 AM
  3. top gear e34 m5
    By kyleN20 in forum 5 Series BMW
    Last Post: 01-08-2006, 02:15 AM
  4. Top Gear!!
    By misfortune in forum 5 Series BMW
    Last Post: 11-14-2005, 08:50 AM
  5. Gear Selector Problem
    By myles in forum 5 Series BMW
    Last Post: 09-05-2004, 04:42 PM
