Results 1 to 5 of 5
Thread: New remote for a '94 540i...umm.
    Jun 2006
    Tampa, FL
    Default New remote for a '94 540i...umm.
    Well, I've been trying to figure out how to program this new remote. I've found what looks to be the alarm module (http://www.realoem.com/bmw/showparts...65&fg=60&hl=23) - under left passenger seat, in front of GM and RM. However, I do not see any place to put the chip found in the remote (which is not the chip I've seen described in most other posts).
    I'm quite baffled at this point.
    This is NOT the chip I see in my remote:
    This is the key I have:
    This is where I located the alarm module, if that's what that is:
    May 2006
    Perth Western Australia
    As far as i know your system MUST be configured using the D.I.S. system at a dealer.......
    Your key doesn't appear to be new, so I'm guessing you changed the battery but had no battery in the remote at all for more than 10 seconds cuasing it to clear?
    Go to a dealer (take any other remote control keys or they'll be barred) and have them reprograme it for you.....
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
    Jun 2006
    Tampa, FL
    Turns out I may have bought a slightly different remote than what I should have...
    The original remote has a small LED shown in my original post. The used remote I bought does not have this LED, and appears to be of a slightly earlier design.
    I do know these remotes can be DIY reprogrammed (holding a button, then pressing another 3 times) , but either my old remote is partially broken (was dropped in water, LED works with new battery) or the alarm has some fault with it. I'd like to determine which, in the most cost-effective manner.
    However, I do not know if I can just buy a matching remote and program it for remote functions. I know the immobilizer code is unique, but I believe I should be able to use the remote still...
    May 2006
    My understanding is that reprogramming the alarm manually wipes any other keys out of the alarm system, maybe this is just the Aus system (315 mhz)?
    I don't know.
    We always use the d.i.s sytem to reprogram the alarm module.
    Is your alarm infrared or radio?
    where is the alarm LED located in your car?
    P.s which photo shows you OEM key? the only key I see is too dark to identify whether is IR or EWS.
    Previous rides:
    BMW
    E34 535i M
    MAZDA:
    Jun 2006
    Tampa, FL
    I believe it's infrared...I have the infrared receiver on the dash. Not sure where the LED is...since I've never activated the alarm.
  1. Key with remote
    By soldado37 in forum 5 Series BMW
    Last Post: 05-25-2006, 06:18 PM
  2. e34 remote key.
    Last Post: 09-18-2005, 11:09 PM
  3. 540i auto to 540i manual
    By Dazbut in forum 5 Series BMW
    Last Post: 04-08-2005, 12:07 AM
  4. E34 key remote?
    Last Post: 03-06-2005, 06:36 AM
  5. 91 M5 remote key help
    By bmwm5sport in forum 5 Series BMW
    Last Post: 03-04-2005, 04:25 AM
