yep, and the washers are about $50 ea. from the stealer. There is a right and left. Maybe you should soak them if the nozzles aren't exactly broken.
Mind your hoses as you take off your bumper cover as they are still attached to the hi pres pump
Hi all,
I am about replace the headlight washer jets soon and I am wondering if I have to remove the front bumber to be able to remove them. If anyone has done this before and can offer suggestions, that would be awesome. Did a check in the archives and couldn't find any relavent info.
Thanks, Shawn
They definately have to come off as each side has 1 broken nozzel. I am getting them used at $40 each. I'll check my bentley manual for steps to take off bumper cover. Thanks for the heads up about the lines, I'll be careful.Originally Posted by 530iTouring
Thanks for the help,
Shawn
