Results 1 to 9 of 9
Thread: Oil on my plugs
    Jul 2004
    Holly Springs,North Carolina
    Default Oil on my plugs
    Changed my spark plugs yesterday after Bill B and i found i had one incorrect spark plug in my car. All my plugs have oil on them. Not much but it is noticeable to the eye and touch. Three questions why? is it a major problem and can I fix it myself?
    Any ideas?
    Michael
    Mustbr8kfree
    1995 525i, Shadowline,EAT chip, Alpine
    Oil on the outside of the plugs means a leaking rocker cover gasket, easy fix.
    Oil on the firing end is a different animal. Let me guess, the different plug was the most fouled if this is the case.
    Oil on the firing end is usually an indicator of worn engine internals.
    The odd plug was probably a replacement for a previously oil fouled one.
    Jul 2004
    The oil was on the threads of the plug. Granted there isn't much at all but there was enough to make Bill and I wonder. I plan on replacing my valve cover gasket soon (just got it yesterday) as I know there is a small leak there. Perhaps that is the cuplrit. Thanks for the response.
    Michael
    Mustbr8kfree
    Clean it all out with carb cleaner or such and use a little anti-seize on the plug threads.
    NC
    Default My thought was to go to a slightly thicker oil...
    Quote Originally Posted by 1995 525i
    Michael
    ...as you could be getting some blowby around the rings. The valve cover gasket will heal the drips outside, but won't solve the leaks inside. I'd go with a 3k change interval and move up to something like 15W40 or 20W50 dino oil since you're not running synthetic.
    His car doesn't smoke though, so it's pretty weird to have oily plugs...
    Bill B.
    95 525i
    sounds like the valve cover gasket.
    NC
    Default porcelain and nut were not wet...
    ...just what was inside the engine.
    Bill B.
    95 525i
    Mar 2004
    Gainesville, FL
    I had the same problem...oil on my plugs. I am going with a valve cover gasket change. My plugs were loose, and I had oil on the threads of my plugs as well.
    A Young Man with a Plan
    ericbendler@yahoo.com
    Default I see it frequently. If you look at the
    cross section of the threads on a spark plug and the threads in the hole when they are screwed in, you'll notice that there is a gap on every thread .
    When they are torqued this slight clearance or gap on the threads makes a spiral channel that oil in the combstion chamber can wick its way up.
    A very small amount of oil is present in the cylinder and combustion chamber when the engine is running, you can have just enough oil coming by the rings and the intake valve guides that it won't show up on the electrode because it will burn off fairly completely but it will wick up the threads on the spark plugs all the way up to the sealing washer on the plugs.
    As long as the oil consumption it still relatively normal i wouldn't worry about it at all.
    Quote Originally Posted by billb
  1. cold plugs or hot plugs, modified gap or stock gap...?
    By Boone.Msi in forum 5 Series BMW
    Last Post: 05-16-2007, 12:20 AM
  2. oil on my plugs
    By ericbendler in forum 5 Series BMW
    Last Post: 12-30-2006, 09:07 PM
  3. New Plugs - Oil
    By uberhahn in forum 5 Series BMW
    Last Post: 08-31-2006, 03:51 PM
  4. Plugs
    By JoshsE34-M50 in forum 5 Series BMW
    Last Post: 09-01-2004, 02:08 PM
  5. Plugs
    Last Post: 08-29-2004, 08:05 PM
