Here's a suggested parts list you can start from...
Assuming this is a M30 motor
- both coolant hoses under the intake manifold
- get 2 new hose brackets for under the manifold
- get new intake and exhaust manifold nuts (12 per side + 4 extra exhaust nuts for the lower part of the intake manifold)
- new 3mm vacuum hoses from the manifold to the FPR and valve cover vent
- new ICV vacuum hose
- replace the 3 inch piece of high pressure fuel line on the injector rail
- consider replacing the o-ring gaskets on the injectors (2 per IIR, tend to be silly price for what they are)
- very easy time for a new water pump
- easy time for new cap and rotor
- new timing chain tensioner plug and spring
- new throttle body to intake manifold gasket
That should get you pretty far along...you don't need all these but I'm sure you can assess what's important for your car.
I'm assuming you'll order a head gasket kit which will get you all the critical gaskets you need for the cylinder head. Be triple careful you don't whack the plastic timing chain rail that sticks up beyond the block. Kill that and you get the pleasure of having to remove the lower front cover which of course means you have to remove and replace the 325 ft/lb crank nut.
Have fun!!
Jeff
Originally Posted by
Mass535Love
I'm planning on replacing my head gasket, I'm going to get a kit from BMAPARTS. Do you guys have any suggestions on other parts near and around there that I should check the condition of and / or replace? I'm on a tight budget of a few hundred dollars. I'm not talking major items, just things that would be easier to replace since I'm doing the head gasket anyway. Things like gaskets, caps, hoses, wires, sensors etc.
Thank you all in advance.
Michael
Bellevue WA
86 Porsche 951 - Track Toy
