Results 1 to 8 of 8
Thread: Foggy Instrument Cluster
    Apr 2005
    Philadelphia
    Default Foggy Instrument Cluster
    My instrument cluster has been like this since the car was purchased. Not sure how/why it would get like this, but wondering if any one out there has had a similar problem or knows of a fix.
    Indiana
    Are all of your vents working? Maybe the far left vent has been blowing behind it somehow. Sounds like a dumb guess. Bet it sucks driving at night huh?
    Apr 2005
    Philadelphia
    Quote Originally Posted by Macv
    Yea, actually, its not too noticeable at night. This picture makes it look worse than it is, but it is there nontheless. It's always there too. I could understand that if I turned on AC or Heat, it would come/go, but that fog is just stubborn!
    Indiana
    Have you tried taking it out and cleaning it, then close it up again and replace it?
    Apr 2005
    Philadelphia
    Nope... Sure haven't. Last time the steering wheel was removed, "clock spring" went bad, causing horn to go out (done at shop). They ended up charging me somwhere around $120 to replace spring and such. I do have one bulb starting to go out, maybe i'll give it a shot, and attempt to clean.
    From my past experience though, isn't the clear part glued to the rest of the cluster? Do they actually seperate?
    Hockinson, Washington
    Just take it apart and clean it.
    Indiana
    Yes you can seperate them.
    If the plastic lens is F'ed up try some of the stuff for cleaning plastic convertible windows. I screwed up some clear plastic with too strong a cleaner and the Meguires stuff saved me.
  1. instrument cluster
    By Mendozart in forum 5 Series BMW
    Last Post: 08-25-2006, 09:37 PM
  2. New instrument cluster...
    By BM-BOY in forum 5 Series BMW
    Last Post: 08-30-2005, 07:15 AM
  3. instrument cluster is always on
    By vader1 in forum 5 Series BMW
    Last Post: 08-21-2005, 02:17 AM
  4. Help - Have the instrument cluster out.....
    Last Post: 11-22-2004, 10:32 PM
  5. Instrument cluster
    By baileydog in forum 5 Series BMW
    Last Post: 10-07-2004, 05:48 PM
