Results 1 to 7 of 7
Thread: Rear Door
    Seattle, Wa
    Default Rear Door
    Does the rear door panel (right) need to be removed in order to replace the Door Handle Inner Right.
    TIA
    Jim
    Quote Originally Posted by JMI
    TIA
    Jim
    It will probably make the job easier.
    I've taken my rear door apart a couple of times, not a hard job.
    Greg
    E30 318iS & BMW K1200LT
    Washington DC
    Yes. I have mine sitting in front of me. The armrest needs to come off and the only way to do this is from the inside of the door panel. Removing the panel takes about 5 min.
    Seattle, Wa
    Probably having some spare "clips" is a good idea. Anything I should be careful about? Don't want to tear/rip/bend anything!
    Jim
    Washington DC
    Remove the 3 screws and pull on the panel around the edge to pull the clips out of the door. Then pull strait up on the door panel to remove it from the center clip. Unhook the door cable and the power window switch. I have never broken a clip when removing door panels. Once it is off remove the 2 screws from the metal center clip on the back of the door panel. Pry the armest off since it is held on by clue. Then just turn the armrest to get it and the black trim piece free that you are trying to remove. The rear doors are easier then the front doors
    Seattle, Wa
    Quote Originally Posted by Eric Clark
    ...Pry the armest off since it is held on by clue. Then just turn the armrest to get it and the black trim piece free that you are trying to remove...
    Thanks for the help, Eric.
    Just a couple more questions. I assume you meant "glue" above? If so, this needs to be reglued? What is the best type of glue/adhesive for the task?
    TIA
    Jim
    Washington DC
    TIA
    Jim
    yep typo. gorilla glue works well
  1. rear door won't open
    By nizmainiac in forum 5 Series BMW
    Last Post: 01-27-2007, 06:20 AM
  2. What is up w/ e36 rear door latches!
    By paul p (chi-town) in forum 3 Series BMW
    Last Post: 03-14-2005, 07:36 PM
  3. WET rear door panels?!
    By Kalevera in forum 5 Series BMW
    Last Post: 01-20-2005, 01:41 AM
  4. Help!!! Rear door locks
    By BobW_535 in forum 5 Series BMW
    Last Post: 02-14-2004, 06:47 PM
