Results 1 to 10 of 14
Thread: BC Remote Display
    Jan 2005
    SF Bay Area
    Default BC Remote Display
    Just wondering what everyone has displayed when they depress the BC remote display by pressing the directional stalk.
    I cycle through:
    -Time of Day
    -Avg2 (fill-up to fill-up; avg1 is oil change to oil change)
    -Range
    -Temperature
    Very handy feature. Only bummer is having to reach over to push the CODE button to turn it off. Too bad it doesn't go off with the last push.
    Steve
    SF Bay Area
    1992 525i/5-spd, 250K mi
    17inch wheels
    Here's how to program instr cluster LCD screen
    Programming the instrument cluster's LCD to display OBC functions when using the turn signal stalk:
    1. turn on ignition (position 2)
    2. press the turn signal lever toward the steering column and hold for 3 seconds until PROG 1 appears in the display
    3. Press the desired OBC function(s) you want to appear on the LCD display (example, I only have time, temp, and range programmed into my LCD display) The order in which function you pick will be the order they appear when you use the "remote" method.
    4. press the S/R button on the OBC to set your "program"
    To cancel the programmed info on the LCD display...press the turn signal lever in for 3 seconds until the PROG 1 appears in display...then press the S/R button on the OBC.
    Pressing the stalk on the instrument cluster (little Check Control stalk on the right side) extinguishes what's displayed in the LCD display...or you can press the CODE button on the OBC to extinguish the LCD display.
    Wellington,New Zealand
    you can have what ever you want.....why turn it off?just cycle through to what you want.i ussually program it on road trips to include range distance and arrival,but also time,and consumption and temp.
    Gone but not forgotten
    Jun 2006
    Melbourne, Australia
    You're all lucky to have BC on your indicator stalks. I'm missing that on my 525i
    dublin, ca
    where is all that about programing it? iv never herd of that before
    Owners manual.
    And see my info above.
    Norway
    Is it possible to program the Tests into the remote display?
    It would be interesting to have instant fuel consumption, voltage or vehicle speed there.
    Eurospec-12/1988-535iL-M30B35-5speed
    May 2006
    Perth Western Australia
    NO..... Not possible.
    The most instant you'll get are time, range and outside temp.
    You can see your instant mpg using the mpg gauge!! LOL!
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
    Norway
    yeah i thought so....
    the mpg gauge is actual pretty accurate, but it very often disapears above the 3.0 mark..
    May 2006
    you mean 30 mark.........
    Previous rides:
    BMW
    E34 535i M
    MAZDA:
  1. CEL / dashboard display
    By timandbim in forum 5 Series BMW
    Last Post: 08-27-2007, 12:23 PM
  2. Radio display goes in and out
    Last Post: 04-03-2007, 06:41 PM
  3. OBC Display
    By slupregime in forum 5 Series BMW
    Last Post: 06-12-2006, 08:02 PM
  4. Outside Temp display gone mad
    By rph in forum 5 Series BMW
    Last Post: 07-21-2004, 06:41 AM
  5. weird display
    By nuwde in forum 5 Series BMW
    Last Post: 06-01-2004, 06:17 AM
