Results 1 to 10 of 15
Thread: considering trade, opinions needed
    illinois, USA
    Default considering trade, opinions needed
    hello everybody. i have a 1990 535i and am considering trading it in on a 1998 328 convertable automatic SOHC 6cyl. the guy said he might take a straight up trade, mileage on the 3 series is unknown but my 535 has 330k miles, is lowered and has a 5spd. both are black. would this be a good trade in terms of having a reliable quick good handling car? i'd hate to see my 535 go, but the 328 is much newer.
    May 2006
    Chile
    Default sohc?
    Is the engine sohc?
    Quote Originally Posted by hatched91
    Jul 2004
    Montreal, Canada
    are you sure you want an automatic????
    It sounds good since your 5 has so much mileage, but automatic is the deal breaker!
    ^°^ ><((({º>°°
    Hockinson, Washington
    That does sound good.
    Take it easy, autos are the whip!
    Quote Originally Posted by SharkmanBMW
    illinois, USA
    yeah, i've heard bmw autos aren't the best, i'm not worried about the drivetrain on my car, everything has been replaced/rebuilt. holds up fine. but it pains me to think of getting an auto convertable, even though it's nice...i'll test drive it later this week and find out whether it's worth the trade or not, both are 6cyl SOHC motors. i'd guess the 328 has more power since it's new though.
    Let me be sure I understand the question. Someone has offered to straight trade an eight year old convertible for a sixteen year old sedan with a third of a million miles. Correct?
    Washington DC
    Maybe it is a flood vehicle? It sounds suspicious since the miles are unknown.
    T·O·R·O·N·T·O
    Straight up trade sounds suspicious... it's not like the 3 has an ///M package or anything...
    You sure you want to throw away a great e34 for something like this?!?
    May 2006
    Perth Western Australia
    The following specs are for a 1999 328ci:
    Engine Size 2793cc (2.8)
    No. Cylinders 6
    Engine Configuration In-line
    Cam DOHC with VVT
    Valves/Cylinder 4
    Compression Ratio 10.2:1
    Engine Cycle 4 Stroke
    Engine Type Piston
    Engine Location Front
    Engine Number M52
    Engine Code M52
    Fuel Type Petrol - Unleaded ULP
    RON Rating 91
    Fuel Capacity 63L
    Fuel Delivery Multi-Point Injected
    Method of Delivery Electronic Sequential
    Induction Aspirated
    Power 142kW @ 5500rpm
    (your M30 is 155 Kw and the Sohc 328ci is around 125Kw)
    Torque 280Nm @ 3500rpm-3500rpm
    Acceleration 0-100Km/h 8.1 secs
    (only .1 faster! why bother)
    Kerb Weight 1285kg
    Tare Mass 1447kg
    Gross Vehicle Mass 1895kg
    It's only .1 of a sec faster to 100 kpm than your 535 (and note this is the VANOS DOHC motor in the example) and the sohc will be 10 kw LESS that my example. the chassis is much more flexible than the E34 and not even 100 kg lighter.......
    Together with the problems with the rag top motors going out of sync and the mundane SOHC non vanos motor i'd give it a miss.
    but at the end of the day it is going to be your car not mine.....just my 2 cents.......
    R
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
  1. Replies: 21
    Last Post: 12-19-2008, 07:07 PM
  2. opinions needed, 540 for s430?
    Last Post: 02-07-2008, 01:04 AM
  3. Intake Manifold Off - Opinions Needed
    By myles in forum 5 Series BMW
    Last Post: 07-07-2005, 04:02 PM
  4. Indy Work Quote Opinions Needed
    By DaCan23 in forum 5 Series BMW
    Last Post: 05-05-2005, 12:28 PM
  5. Replies: 11
    Last Post: 08-17-2004, 09:18 PM
