Won't lose the cruise
Brosher,
I bought my 540i/6 with the stock 2.93 open. I had the chance to pick up a 3.15 LSD cheap here in Detroit so I grabbed it. The swap is fairly straightforward. Make sure you change the input flange seal, since you have to swap flanges anyway, and put NEW LSD gear lube in. I did notice a bit of difference in the performance. Not quite as much as if you'd chipped it, but you CAN tell a difference. I definitely wouldn't go higher than 3.23 MAX for the diff ratio, or your first gear will be almost useless! The cruise control worked just fine afterwards.
Brian Harston
Waterford,MI
1995 540i/6
