Thread: Coolant Level sensor specs
    Gainesville, FL
    Default Coolant Level sensor specs
    Is the coolant level sensor simply an open-closed switch? I've "jumped it out" before and still recieved the low coolant warning, but if i change the entire thing it will go away and read correctly.
    does anyone know the ohm-out for it (coolant level correct), if it's not an open-closed system?
    May 2006
    Perth Western Australia
    It's a magnetic reed switch.
    normally open until closed by the magnetic strip in the float.
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
    Check the 2 wires, they break easily as they are very thin. If you still get a low signal when you bridge the 2 cables at the plug, search for a broken wire , they go to the CCM. I soldered 1 wire last weekend.
    Nov 2005
    Mo!
    I'm still battling a low level warning on our '93 525i.
    Since I'm relatively new at testing this type of thing, what's the easiest way to bridge the coolant level sensor? I've replaced the sensor and I still get the message - so I'm assuming it is in the wiring or the CCM.
    I've tried searching the ETM for info on the sensor and how it interacts with the CCM and no luck.....
    Thanks for any advice/suggestions!
    Derbyshire, UK
    Quote Originally Posted by shadowpuck
    Pull the plug and stick a bit of wire in the connector holes.
    1997 535i V8
    Nov 2005
    Mo!
    Thank you for the info - I've added that to my list....
    I happened to get lucky and won a lot of 3 CCM's on eBay for 1.25....yay!
    They arrived today and I tried each one until I found one that cleared the coolant level message - the second one did the trick....
    Sounds like there might be an internal issue with my CCM and the other one I tried....I'm wondering, is it perhaps similar to the LKM where some soldering/repair of an internal connection/resistor will do the trick?
  1. Coolant level after new sensor and MPG
    By JetMech in forum 5 Series BMW
    Last Post: 03-04-2009, 11:00 PM
  2. coolant level sensor
    By robert g in forum 5 Series BMW
    Last Post: 11-16-2007, 04:30 AM
  3. Coolant level sensor etc etc.
    Last Post: 01-06-2006, 12:17 PM
  4. coolant level sensor
    By riot in forum 5 Series BMW
    Last Post: 12-05-2004, 10:15 PM
  5. where is the coolant level sensor?
    By PABLO in forum 5 Series BMW
    Last Post: 09-20-2004, 11:23 PM
