basicly go with 1mm, use an old gasket to scribe a mark onto machinists blue around the chamber and blend it in, no sharpies except where the gasket contacts the head. you dont want to cut too much material cause you will drop compression. When your cutting the head do a little cutting at a time in ALL chambers, not one at a time so it will be more consistant. Measure with a burette and plexiglass when done to equal all the CC's out, you dont want any more than about 1 cc difference.
