Got the new fan clutch put it in, knock on wood everything seems to be going fine. One question though. When I took the fan out I think it was put in the wrong way last time. The actual fan has a deep recess in one side and only goes in slightly on the other side. I put it on the side where it "stuck out more" because you can see the marks from the bolts and the small 'grooves" the the clutch has put in the plastic from years of use. The odd thing though is that the fan was on the other way when I took it out. (in the deep side.) Second, where is the ICV on the M60 engine in this picture:
Here's how I put the fan on (the deeper side is facing the water pump)
Is it anywhere near the throttle cable?? Sorry for sounding like an idiot, but it's hard to explain the fan situation...
Last but not least, here's the tool I made to hold the nut while turning with the wrench. I recessed the two holes so I was able to turn the nut with a regular sized wrench.
