This only happens sometimes, but I've had my car for almost 2 weeks now and this has happened maybe 5 or 6 times. It's rather annoying and I bet the fix would be simple.
Anyway, most of the time I turn the key and it'lll start up within 1 or 2 seconds and everything is fine and normal. Once in a while I try to start it and let go of the key after the typical 1-2 seconds and it doesn't run. Then I have to sit there and crank for a good 8-10 seconds before it starts. Sometimes when that happens it'll "catch" and run about 5 seconds in but it'll idle rough and low speed and die out, but then the next crank it'll start right up in 1 or 2 seconds and everything is fine. The other times it'll take the full 8-10 seconds and then it'll start up and run fine.
Its weird... and its irritating, and kind of embarrassing. A neighbor suggested I clean the fuel pump relay's contacts, but I didn't know which one was the fuel pump relay, so I cleaned them all, and wiggled them to make sure they seated well. That didn't work apparently.
Once I'm running, normal or not, everything is fine, idle's good, runs great, its just that starting thing.
Any ideas? I'm kinda stumped.
