Results 1 to 10 of 25
Thread: Oil Pressure
    Jun 2005
    Quote Originally Posted by Morgenster
    Wasn't this supposed to be somewhat normal?
    I thought oil pressure only gets to an acceptable level after a second or two on account of the oil pump just kicking in.
    That is sort of the question. How long is too long? The first six months I owned the car the oil pressure light went out quicker. It went out with all the other start up lights. Now it lingers. It doesn't linger that long, but it is a definite increase in how long it stays on.
    shouldnt come on at all if the canister dont drain back. if the oil holds and stays then its solid pressure as soon as the engine is turned.
    time to look into the canister, they should only be about $400.00 at the dealer.
    Jun 2005
    ouch
    your the only one on here with money, me personally id try the shogun ball fixer.
    Quote Originally Posted by Gayle
    ouch
    May 2006
    Perth Western Australia
    BOLLOCKS! The oil pump is empty when the engine first turns........plus the oil galleries in the head drain back overnight.
    The light will always illuminate for half a sec when starting cold even with a full cannister, the oil has to flow upstairs to the head to switch the light off in a 535 (2 oil pressure switches on them, 1 for the DME, one for the idiot light)
    An intermittant light at idle when the engine is hot is a concern not a second or two delay in it going off first thing in the morning..........
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
  1. What could cause low oil pressure?
    By ber55ber55 in forum 5 Series BMW
    Last Post: 11-27-2006, 04:08 PM
  2. Low oil pressure and I want to die..
    By nmwaldron in forum 5 Series BMW
    Last Post: 09-18-2006, 12:00 PM
  3. Oil Pressure Test Kit
    By Andrew in forum 5 Series BMW
    Last Post: 12-27-2005, 06:05 PM
  4. Low oil pressure?
    By jjg43 in forum 5 Series BMW
    Last Post: 09-27-2004, 09:11 AM
  5. AC Pressure
    Last Post: 06-12-2004, 07:44 PM
