The PO gave me a repacement door panel(right rear door-- the same one that had the broken window and regulator problem) that he ordered before but didn't get a chance to install before selling the car. I guess his dog freaked out and chewed/ate some of the fiberglass at the top of the door panel molding. He did a good hack job or piecing it back together, but clearly it needed replacing.
So I went up and got this door panel to install at my convenience-- this past weekend. I go to install it and the upper back clip just won't fit. I brought the door panel inside to compare to the old damaged one and I couldn't believe it! That clip, and only that clip on the broken panel has two mounting points, one is just above the other. The replacement does not have the second(correct) mounting point. Nothing....nothing, its a simple as it seems it should be. So I'm left with a what to do situtation.
I could just go without the clip, but since its a corner spot its probably more important than others in holding the panel tight. The vinyl around where this mounting point would be is a big loose, so I'm toying with the idea of drilling a hole in the fiberglass and finding a screw that I can fit in under the vinyl, and try to screw into a clip. I don't suppose anyone has run into this problem and found a better solution, but if so I'd love to hear it. Oh, in case anyone is curious, the anchor points for the clips are integrated into the fiberglass and it does not appear possible to remove and replace here.
