In line with my facination with halo projectors, I'm about to get these (though not from here):
http://www.flatoutperformance.com/Me...gory_Code=Bda8
Has anyone actually seen them or tried them?
I wonder if the light cut off is for driving on the other side of the road?
I have them in my car and i used them with hid kit . Untill now no problems.
BMW FOR EVER
I also have those. I have had some problems with the plastic clip that is holding the headlight onto the horisontal adjustment screw. OEM BMW clips fits so i replaced them all. The glass is very thin, and a small stone will break through easy... At least it did on a friends car, and the glass was like the one use in wine glass.
Light cutoff for RH vs LH driving is the same as on the OEM lights, you just turn the projector 30 degrees.
Eurospec-12/1988-535iL-M30B35-5speed
woo woo... wait... the cutoff is the same meaning a euro cutoff _/ or north american _/- ? Also, any comments on the halo brightness? Bulbs? Hotspots?Originally Posted by Espen
EDIT: actually, nevermind the cutoff... if you can rotate 30 deg, then it's the euro cutoff![]()
the cutoff is __/ ___/ or for RH \___ \___
Brightness is very good! I use the same bulbs as i used in the old lights, but now i got a blue-ish light. The adjusment on theese lights are hard, and I never got mine like I want it. (They are to narrow)
Hotspots? not sure what you mean by that.
Actually I meant the brightness of the HalosOriginally Posted by Espen
I'll be putting HIDs on there so no problems with brightness. I'd assume they are H1 as well.
On that note, I mean hotspots on the rings:
See the left high beam ring? You see four bright dots where the halo rings light up. Do you see that in the In.pro as well?
Yes you can see this four dots when the rings light upOriginally Posted by Qube
BMW FOR EVER
Yes its easy to see the 4 leds.. They look very much they same as those on the picture there.Originally Posted by Qube
Here`s a pic of mine..
They are not that bright as on the picture, my camera is lying a bit.
$440? Hope those things cook eggs for you as well. I'd spend my money on Euro Ellipsoids from Hella prior to that. No Angel eyes, but hey, I hadn't heard of "Angle" eyes either as listed on that website![]()
