Results 1 to 5 of 5
Thread: Dead or Alive Dashboard Fuel Indicator Needle
    Jun 2006
    Default Dead or Alive Dashboard Fuel Indicator Needle
    Guys,
    Strange and annoying: i have a 97' e34 530i with a sometimes dead, sometimes alive dasboard fuel tank indicator needle.
    When the car has been parked in the sun for a while and it is hot inside the car, the needle comes to life; I start the car and the needle on the dash jumps up to tell me how much fuel is left in the tank (e.g 40 litres). I drive for a while, the needle drops back to 20 litres or so. (??)
    Should the car be parked in the shade or when it's dark, and the car is then started, the needle doesn't move. Dead. I drive for a while; it remains 'dead'.
    I suspect this problem be electronic and heat related--expanding, contracting. Trouble is, i don't know how to solve it.
    Thanks for all the help so far. This forum has been reaaly great!!
    Bart
    USA
    you need a new fuel sending unit, they die eventually, or just get more and more inaccurate over time.
    you need the part, plus some gaskets, plus a tank low on gas (easier that way) and some large rubber gloves to keep the gas off your self.
    the unit is in the tank and accessable from the trunk. you pull the matts up, and its on the right side.
    http://www.bmwe34.net/e34main/mainte...e/FuelPump.htm
    thats most of the procedure, minus the pump replacement.
    Jun 2006
    Quote Originally Posted by BillionPa
    Thank you!
    I'll get right on it.
    Bart
    Thats a rare car. Is it a 1997 or an e34, tough to be both.
    The capacitors in the instrument cluster can do funny things with the needles if they are going bad.
    Quote Originally Posted by bbart
    Guys,
    Bart
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    Jun 2006
    Quote Originally Posted by DanH
    Thanks for your post !
    It's like this; I am Dutch and live in Indonesia. Now, the E34 model was discontinued in 1995 except for the 530i V8. They kept making them until discontinuation in 1997 when the all new 530i arrived in Indonesia.
    Bart
  1. Replies: 0
    Last Post: 02-27-2010, 01:15 PM
  2. Replies: 0
    Last Post: 02-27-2010, 01:13 PM
  3. low fuel indicator light
    By Mendozart in forum 5 Series BMW
    Last Post: 06-06-2006, 06:16 PM
  4. Fuel indicator
    By Sami El-Sharkawi in forum 3 Series BMW
    Last Post: 04-03-2006, 02:20 PM
  5. E34 Fuel indicator light failed
    By uktechnics in forum 5 Series BMW
    Last Post: 08-25-2004, 08:05 AM
