Are you telling me my trans control module is worth that much?
I took my car for service today because I had the trans error message come up yesterday and the car went into limp mode. I took the terminals off the battery and let the system reset itself. Car drove fine after I did that and drove fine on the way into work this morning.
At the shop the guys told me that I needed the following:
Transmission Control module: $1536.00
Oil Pan Gasket: $343.00
Transmission pan gasket: $226
Coolant expansion tank: $236
Total: $2341
Not sure about prices for a control module, but does this all seem a bit high? Can I get a used one? If so, is it hard to install? They said they would install a used one if I wanted to look for one.
They told me my pan gaskets were leaking (although I haven't noticed any leaking) and my coolant tank was leaking (although, again, I haven't noticed any leaking).
Can I keep driving without changing the trans module? Will I damage my car more by doing so? Cn I get a used one and from where?
Thanks in advance for your help.
Michael
Mustbr8kfree
1995 525i, Shadowline,EAT chip, Alpine
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
Maybe. Seeing as how they are charging $343 for an oil pan gasket that is worth $23, I'm sure there is a slight mark up.Originally Posted by yaofeng
Mustbr8kfree
Did you take it to a BMW dealer?
if you splurge for that you really should be sending me installments for advice.
They are there to make money I understand but 10,000% upcharging because they dont have a clue and dont want to get stung is assinine. I'll bet they didnt even properly check the trans fluid whick can cause that error and limp mode.
start simple
transmission service with filter/gaskets and fluid change at an Indy should only cost beteen $100-$150 depending on labor rates. I would take the car somewhere else for a second estimate.
The trans program issue is the only one that seems to be a potential show stopper. Other people will now more. good luck.
Yeah, seems high. You'll want to get them to disclose their projected 'labor' time for all that, then we'll see the waste.
I didn't...Originally Posted by dbals
Mustbr8kfree
If you really need a new computer...
Used trans computers available for about $50 + shipping.
Click here for a link to car-part.com trans computer listings...
DanH
1989 535iA 254k Miles
1992 535iM 330k Miles
Thank you everyone for your input. I'm on the prowl for a used TCM.Originally Posted by Qube
Mustbr8kfree
