Originally Posted by
Rus
I seem to have a leak at the upper timing cover bottom edge. The leak is on the passenger side of the engine and appears to be coming from the point where the upper timing cover, the head gasket, and the lower timing cover gaskets meet up. I remember tightening a loose bolt in this area when I was changing the water pump, but am not sure if it was the CPS bolt or something else that seemed loose. I've washed off all the oil on the front of the engine and the leak is pretty apparent...albeit I'm not sure which of the three gaskets is causing it. I wouldn't mind taking care of the CPS bolt once and for all while I'm tearing into this. What parts are required to fix this possible leak?
Also, the vibration that I think I'm getting is very slight and I don't think its related so much to the driveshaft as to suspension. What bothers me is the slight whining/ticking noise that becomes apparent closer to 80 mph or so. It seems to increase with speed and comes from the center console beneath the e-brake. The transmission has had a recent filter service and has fresh fluid in it (red in color, smells good). I'd like to blame something simple like the center bearing. Sorry for the unclear symptom description.
As far as the sensor goes, I'm not considering anything other than OEM Bosch. My dilemma is between the sensor that comes with the connector attached and the one that just comes with the bare wires, thus requiring soldering on the original connector.
As always, advice and opinion are appreciated.
