Results 1 to 4 of 4
Thread: test paper for checking if exhaust gas is in coolant
    Default test paper for checking if exhaust gas is in coolant
    How is that called in proper English and does someone know a link to a website where this can be bought?
    Someone is asking me some questions and I am afraid that he might have a blown headgasket.
    Thanks volks
    Litmus paper?
    Default Most of the kits nowdays use a chemical instead that
    changes color to indicate head gasket leakage like this one
    Thanks volks
    Great, thanks, for you Bill cheap, as you use it probably often. For a one time user cheaper test paper might do.
    http://www.pelicanparts.com/catalog/...CAT439_pg9.htm
    Quickly pinpoints combustion leaks. Checks combustion leaks caused by bad head gaskets, cracked blocks and cracked or warped heads. Indicating fluid changes from blue to yellow when exposed to combustion gases in the radiator. Connect the hose to any vehivle vacuum line. Place tapered end of tool into radiator opening after draining of some coolant. With the engine running, the vehicle's vacuum draws vapors through the indicating fluid for testng
    Includes leak detector and testing fluid.
  1. BMW paper brochures -no more?
    Last Post: 08-27-2009, 05:33 PM
  2. Checking Coolant For Exhaust
    By Fetch in forum 5 Series BMW
    Last Post: 01-11-2007, 11:56 PM
  3. Advice on coolant system pressure test
    Last Post: 11-05-2006, 04:49 PM
  4. Paper Oil Pan Gaskets??
    By John B. in forum 5 Series BMW
    Last Post: 06-21-2006, 02:25 PM
  5. Kaboom...what blows coolant on the exhaust manifold?
    By mancini_mark in forum 5 Series BMW
    Last Post: 06-29-2004, 08:41 PM
