Results 1 to 7 of 7
Thread: Oil in Coolant
    Germany
    Default Oil in Coolant
    New to bimmer.info have a 1992 e34 535i european model. I have oil in my coolant but there is no coolant in my oil. I have read conflicting reports as to whethor or not I have a blown Head Gasket, is this the case? If so what would you estimate the cost to be?
    Thanks Trevor
    I just finished a headgasket job on my 535i. It took many hours of labor and a few hundred $ in parts. At the minimum you'll want to get a upper engine gasket set which was around $100 and new headbolts for a few $ apiece. Its a doable job if you have another car to drive while its apart.
    Search the forum for more info, there are many of threads on doing the M30 headgasket replacement.
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    auto trans? maybe you have coolant in the trans instead of the engine.
    might just be an oily substance and not necessarily motor oil. also if someone already replaced the head gaskets there could have been residual oil in there. is it a large amount of oil or what?
    Hockinson, Washington
    Quote Originally Posted by joshua43214
    What
    Alex,
    Can be on some models, where the radiator (sectionally) is splitted into coolant and trans fluid cooling, like in my 750 radiator.
    Melbourne, Australia
    Headgaskets usually blow where subject to extreme heat and pressure ie. near combustion chamber or coolant passages. Hence you often find coolant in the oil but not other way around - but not impossible. You need to investigate further eg. any recent repairs carried out on engine which could have caused oil to mix with coolant?
    M30 engine headgasket commonly blows near cylinder no 6, as mine did.
    I paid about $100AUS for Goetze brand gasket set in Australia - ought to be cheaper in Germany.
    Bill G Melbourne Australia
  1. oil in coolant
    By dwaynos in forum 5 Series BMW
    Last Post: 06-12-2008, 06:12 PM
  2. Check coolant message, how do you "top off" coolant
    By gmannino in forum 5 Series BMW
    Last Post: 01-06-2007, 01:13 AM
  3. Where is the coolant going?
    By Jay 535i in forum 5 Series BMW
    Last Post: 02-19-2006, 11:21 AM
  4. BMW coolant
    By Drooby in forum 5 Series BMW
    Last Post: 03-28-2004, 01:57 PM
  5. Replies: 9
    Last Post: 02-18-2004, 11:05 AM
