Results 1 to 5 of 5
Thread: Just replaced subframe bushings, pitmans, front control arms...
    Default Just replaced subframe bushings, pitmans, front control arms...
    It always pays to research the forum before starting repairs. I was a bit apprehensive about doing the subframe bushings but read a couple of posts where guys pushed them out using a little heat and the weight of the car. So first, I made a block to push the old bushing out using a piece of 2" thick mahogany. You have to make the outer edges of the block just slightly less in diameter than the bushing. I then borrowed a heat gun (it's a high heat version of a hairdryer) and a bottle torch as backup. I jacked the car up and put a jackstand under the outer frame near the normal jacking point. Then I placed the jack under the subframe near the bushing and removed the large nut and two small bolts that attach the bracket to the subframe bushing and body. With the bracket removed, I put the nut back on the large pin and drove it up until I could remove it from inside the car under the rear seat. Then I slowly lowered the jack to allow the subframe to come down. I had to pry it down slightly to install my wood block. I then used the heat gun to thoroughly heat the area of the subframe that holds the bushing. When it was fairly hot, I began to jack the subframe up. It didn't take long before the bushing began to slide right out of the subframe. Then finally it was out. I cleaned the subframe bore. I replaced the wood block between the floorpan and the subframe. I then took the new bushing (frozen solid from a night in the freezer-figured it couldn't hurt), put a little water on the outer casing, and positioned it on a piece of softwood on the floor jack. I used the heat gun again to heat the subframe. I aligned the bushing in the hole properly and began jacking it up. The bushing pushed up into the hole pretty easily but stopped about 3/4" short. I then lowered the subframe enough to heat it again with the heat gun. I put a little more pressure on it with the jack and it pressed the rest of the way into the subframe. I put the pin back into the hole and drove it back down to seat the knurled area. You have to whack it pretty hard to make certain it's fully seated. Then I pushed the subframe back up and installed the bracket. Then, on to the other side.
    While doing this work, I also replaced the short pitman arms that go between the subframe and trailing arm. I also replaced the control arms up front and put new 750i bushings in the thrust arms. Finally, I replaced the front sway bar end links.
    All in all, this work really tightened up my 1991 535i. I believe putting new subframe bushings and pitman arms really helped the rear end a LOT! Mine used to always feel like the rear end was about a half step behind the front end. Now it feels much more connected. However, the steering response is still not as precise as I wish it was. I think the only cure would be to replace the steering box with a proper rack and pinion system with a little quicker ratio.
    If you choose to do any of this work, do your homework on this and other BMW forums. If you have the tools and the patience, you can do quite a bit of your own work. Most importantly, always make certain that the car is safely and adequately supported if you're going to under it.
    Grace and peace,
    Robert K
    1991 535i
    PA
    I need to do new subframe bushings too - kind of one of those things I've been putting off!
    Good work.
    Good work - a little ingenuity saves a lot of $$. I think that's the trick to being a good shadetree mechanic, being able to get the job done WITHOUT having the $400 tool that the experts use.
    Re: the steering, I bet you can get the roller gear really tight with some work. My previous 535 (the twin of yours, 1991, granitsilber over dove) had some play in the steering but my current one is rock solid. Turn the wheel a millimeter, and the wheels respond. Well, maybe two mm. The PO did all the magic so I don't know what the silber bullet was, but mine is all stock and still tight so there's hope.
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
    Dunlap Illinois
    Good work Robert, it pays to do planning on a project. Freezing the bushings overnight is an excellent idea. Plus, you can rub them across your brow when using the heat gun...=)
    Enjoy the ride.
    Jr
    I just love this method. The first time I read about it I decided to try it, but my bushings are not dead yet so I haven't yet been forced under there with a heat gun blocks and jack etc.
    But it's coming. Thanks for the thorough description, I am sure it will encourage many others to attempt the task. Great stuff Nick
  1. M5 bushings on thrust and control arms
    Last Post: 04-21-2009, 10:49 PM
  2. Replaced the rear subframe bushings yesterday
    By zmuff in forum 5 Series BMW
    Last Post: 02-04-2007, 02:30 PM
  3. Bushings for Upper Control Arms
    By magicfox in forum 5 Series BMW
    Last Post: 10-19-2004, 11:48 AM
  4. Replies: 1
    Last Post: 09-10-2004, 03:23 PM
