I wonder if maybe you're not bleeding correctly. The m50 bleeds pretty easy, but the first time I did it I wasn't doing it right. With the bleed screw out start engine and fill the reservoir all the way to the top till it starts crossing over. Keep adding coolant as needed and wait till just coolant is flowing from bleed screw with no bubbles showing. Hope this helps.
