Results 1 to 7 of 7
Thread: New transmission...Again...
    Default New transmission...Again...
    Well, I got the trans program message for the second time in 5 months. First time, when we drained the transmission, ATF was black as hell and smell burnt fron 12 feet away, full of metal shavings. So no time to screw around, I changed it. Being a cheap bastard, I found a used one for $800. All was well until last week.
    Trans program came on and the tranny went to ****... Went thru all the check procedures and no dice. Took it to a specialist this time. Did his thing, finally opened the pan and voila, full of shavings again. He say's they're something grinding up inside, possibly the 3rd and 4th gear. But he's positive, it's toast...
    Checked with the junkyard. Here, the law gives us 3 months warranty. I bought the tranny in March so they basically said I could choke on it. What really pisses me off sometimes about my BMW is I take care of it as much as it needs and I still get screwed. I have friends who drive shitboxes with over 200000km and they never changed their ATF and their cars are still running...Seems a little unfair.
    Moral of the story : Screw the lifetime tranny fluid. Have your tranny serviced. I thought all was good with the first one because of it and it blew up at 155000km so my fault... Don't be a cheap bastard, if it needs a rebuild, reduild it. Everything else is a gamble and the house always wins in the end and you lose...
    End rant.
    Jeff
    I prefer to be misunderstood rather than having to explain myself all the time...
    USA
    i believe only the 540 had lifetime fluid, standard ATF changes for other models is 30-50K depending on driving conditions... mines probably closer to 20K hehe.
    HOWEVER.... the fact that there are so many shavings leads me to believe something along the driveline isnt balanced or in line with the tranny, and its pulling the input shaft in a direction other than straight on. double check the driveshaft and differential mounting hardware, as well as the engine mounts.
    Quote Originally Posted by BillionPa
    I realized the lifetime fluid thing too late. I guess I'll be paying for being asleep at the wheel...
    I discussed your second point already as I too began feeling suspicious of other causes. My mechanic said he always check those things went he rebuilds and reinstalls a tranny so we'll have to wait and see...but thanks for pointing it out...
    Jeff
    servos and etm's
    a bad trans ecm will fry as many trannies as you can throw at it (Daycoyote hold the tranny pics please)
    Jun 2005
    Cleveland, OH
    servos and etm's
    I got the set of dvd's with them for you.. .in my hands....
    not sure why you wanted them....
    I miss my e34
    ohhh boy ...man... I cant "not do it"
    Quote Originally Posted by dacoyote
    Here ya go Chuck!
    heh
    May 2005
    central coast nsw au
    just learnt that one the hard way myself. full tranny rebuild underway as we speak. at least she'll be right for another 250k+ with regular oil changes. lifetime doesnt mean ****! best of luck.
  1. Transmission Oil
    By Roderick in forum 5 Series BMW
    Last Post: 01-03-2007, 05:29 PM
  2. 323 transmission
    By scott540 in forum 3 Series BMW
    Last Post: 01-17-2006, 07:35 PM
  3. What transmission do I have?
    By olsan100 in forum 5 Series BMW
    Last Post: 10-05-2005, 04:20 AM
  4. transmission oil
    By mikedev10 in forum 5 Series BMW
    Last Post: 10-16-2004, 12:47 PM
