oil change!
grab some Lubro Moly MoS2 oil treatment, and dump that in there too, since the car will need it!
i would remove all the fuel from the fuel lines and rail, manually clean the injectors, put on new o-rings, then reinstall and pressurize it with manual voltage to the fuel pump... after dumping all the old gas and replacing the fuel filters that is. get some lucas upper cylinder lube for the new gas, as the pump and injectors should have ample lubrication as well as the engine.
i would strongly consider VentoGT's advice about insp. 2.
in terms of brakes, the pistons are probably toast, get all new (or rebuilt, whatev) replacment calipers and new rotors with new pads. grab new lines too. have the mechanic check for pervasive rust on all the steel brake lines under the car, and the steel fuel lines. you dont want one of those to start leaking under pressure.
get new intake manifold and throttle body gaskets, clean out the throttle and ICV, replace all the exterior light bulbs, new oil pan gasket (check the pump bolts and chain play down there, make sure there isnt any rust inside the engine!!!)
well, yeah there is a lot, dont forget anything important!
